A-111-2 question
2016-09-08 by Neil Kagan
Hi people, Does anyone know if the new VCO has thru zero capability? It looks like it from the LF control being able to go to 0 but there isn't specify mention. Neil Sent from my iPhone
2016-09-08 by yahoo@doepfer.de
The A-111-2 has no thru-zero feature but only a manual control and a CV input for linear frequency adjustment/modulation. With all controls at minimum the oscillation nearly stops (typ. 1Hz in VCO mode). But we are working on a thru zero version of the A-111-2 (probably named A-111-4). But it's too early to publish any details as the circuit is a bit more complicated. It's based on a suggestion by Doug Curtis in his documents we obtained while we were the European distributor for the Curtis chips in the the eighties. The circuit is similar to the CEM3340 based thru zero VCO by Juergen Haible but with a few more features (like zero point modulation). Best wishes Dieter Doepfer
> Hi people, > > Does anyone know if the new VCO has thru zero capability? It > looks like it from the LF control being able to go to 0 but there > isn't specify mention. > > Neil
Thanks Dieter, Can I ask what the application of a manual drop to zero is? Neil Sent from my iPhone
> On 8 Sep 2016, at 18:56, yahoo@doepfer.de [Doepfer_a100] <Doepfer_a100@yahoogroups.com> wrote: > > The A-111-2 has no thru-zero feature but only a manual control and a CV > input for linear frequency adjustment/modulation. With all controls at > minimum the oscillation nearly stops (typ. 1Hz in VCO mode). But we are > working on a thru zero version of the A-111-2 (probably named A-111-4). But > it's too early to publish any details as the circuit is a bit more > complicated. It's based on a suggestion by Doug Curtis in his documents we > obtained while we were the European distributor for the Curtis chips in the > the eighties. The circuit is similar to the CEM3340 based thru zero VCO by > Juergen Haible but with a few more features (like zero point modulation). > > Best wishes > Dieter Doepfer > > > Hi people, > > > > Does anyone know if the new VCO has thru zero capability? It > > looks like it from the LF control being able to go to 0 but there > > isn't specify mention. > > > > Neil > >
2016-09-12 by yahoo@doepfer.de
The drop to zero is not the important thing (except for LFO applications where the modulation can stop and continue again when the linear control is turned up again). But the linear frequency bias/offset is important because the linear FM is different when the bias/offset gets lower. Usually VCOs even with a linear FM input have no linear frequency control. The internal circuit of the VCO multiplies the shares of the linear and exponential section to define the VCO frequency. Without the manual linear frequency control the linear share (without linear FM) has a fixed value which is typically near at it's maximum. A linear FM with e.g. 1 Vpp applied to the circuit is totally different compared to a situation with e.g. half the linear frequency bias/offset. With the LF control you are able to control the linear FM much better than without this feature. The standard VCO situation of the A-111-2 is with LF control fully CW (i.e. the linear share near to maximum). Best wishes Dieter Doepfer
> -----Ursprüngliche Nachricht----- > Von: Doepfer_a100@yahoogroups.com [mailto:Doepfer_a100@yahoogroups.com] > Gesendet: Donnerstag, 8. September 2016 22:00 > An: Doepfer_a100@yahoogroups.com > Betreff: Re: AW: [Doepfer_a100] A-111-2 question > > > > > > Thanks Dieter, > > > Can I ask what the application of a manual drop to zero is? > > > Neil > > Sent from my iPhone > > On 8 Sep 2016, at 18:56, yahoo@doepfer.de [Doepfer_a100] > <Doepfer_a100@yahoogroups.com> wrote: > > > > The A-111-2 has no thru-zero feature but only a manual control and a CV > input for linear frequency adjustment/modulation. With all controls at > minimum the oscillation nearly stops (typ. 1Hz in VCO mode). But we are > working on a thru zero version of the A-111-2 (probably named > A-111-4). But > it's too early to publish any details as the circuit is a bit more > complicated. It's based on a suggestion by Doug Curtis in his documents we > obtained while we were the European distributor for the Curtis > chips in the > the eighties. The circuit is similar to the CEM3340 based thru zero VCO by > Juergen Haible but with a few more features (like zero point modulation). > > Best wishes > Dieter Doepfer > > > Hi people, > > > > Does anyone know if the new VCO has thru zero capability? It > > looks like it from the LF control being able to go to 0 but there > > isn't specify mention. > > > > Neil > > > > > >
2016-09-14 by Neil Kagan
Ah I see thanks Dieter; it took a few reads but I think I understand! Regards, Neil Sent from my iPhone
> On 12 Sep 2016, at 13:42, yahoo@doepfer.de [Doepfer_a100] <Doepfer_a100@yahoogroups.com> wrote: > > The drop to zero is not the important thing (except for LFO applications > where the modulation can stop and continue again when the linear control is > turned up again). But the linear frequency bias/offset is important because > the linear FM is different when the bias/offset gets lower. Usually VCOs > even with a linear FM input have no linear frequency control. The internal > circuit of the VCO multiplies the shares of the linear and exponential > section to define the VCO frequency. Without the manual linear frequency > control the linear share (without linear FM) has a fixed value which is > typically near at it's maximum. A linear FM with e.g. 1 Vpp applied to the > circuit is totally different compared to a situation with e.g. half the > linear frequency bias/offset. With the LF control you are able to control > the linear FM much better than without this feature. The standard VCO > situation of the A-111-2 is with LF control fully CW (i.e. the linear share > near to maximum). > > Best wishes > Dieter Doepfer > > >> -----Ursprüngliche Nachricht----- >> Von: Doepfer_a100@yahoogroups.com [mailto:Doepfer_a100@yahoogroups.com] >> Gesendet: Donnerstag, 8. September 2016 22:00 >> An: Doepfer_a100@yahoogroups.com >> Betreff: Re: AW: [Doepfer_a100] A-111-2 question >> >> >> >> >> >> Thanks Dieter, >> >> >> Can I ask what the application of a manual drop to zero is? >> >> >> Neil >> >> Sent from my iPhone >> >> On 8 Sep 2016, at 18:56, yahoo@doepfer.de [Doepfer_a100] >> <Doepfer_a100@yahoogroups.com> wrote: >> >> >> >> The A-111-2 has no thru-zero feature but only a manual control and a CV >> input for linear frequency adjustment/modulation. With all controls at >> minimum the oscillation nearly stops (typ. 1Hz in VCO mode). But we are >> working on a thru zero version of the A-111-2 (probably named >> A-111-4). But >> it's too early to publish any details as the circuit is a bit more >> complicated. It's based on a suggestion by Doug Curtis in his documents we >> obtained while we were the European distributor for the Curtis >> chips in the >> the eighties. The circuit is similar to the CEM3340 based thru zero VCO by >> Juergen Haible but with a few more features (like zero point modulation). >> >> Best wishes >> Dieter Doepfer >> >>> Hi people, >>> >>> Does anyone know if the new VCO has thru zero capability? It >>> looks like it from the LF control being able to go to 0 but there >>> isn't specify mention. >>> >>> Neil > > > > ------------------------------------ > > ------------------------------------ > > > ------------------------------------ > > Yahoo Groups Links > > >
