> On 7 Nov 2016, at 21:47, Diego Ragnini diegora@free.fr [Doepfer_a100] <Doepfer_a100@yahoogroups.com> wrote:
> Thanks a lot,
> indeed, the idea is that the mixed signal should go through an A-138d CFX to be sent to a stomp box. A eurorack level signal here, usually, needs to be very much attenuated (as far as I know). So, I did believe that in my case things should work enough well.
> Best, Diego
>> Il giorno 07/nov/2016, alle ore 22:34, "Jacco Ville jaccoville@yahoo.com [Doepfer_a100]" <Doepfer_a100@yahoogroups.com> ha scritto:
>> Hello and welcome,
>> Like the purpose of the module says, it's an attenuator so it's not likely that it amplifies.
>> However, attenuating the hottest source can possibly match with the others who aren't attenuated.
>> This might result in a low total signal which has to be amplified again.
>> There are modules that are made for these tasks.
>> Cheers
>> Jacco Ville
>>> Op 7 nov. 2016 om 22:26 heeft Diego Ragnini diegora@free.fr [Doepfer_a100] <Doepfer_a100@yahoogroups.com> het volgende geschreven:
>>> Greetings to everybody,
>>> I am a newbie on this group.
>>> I need some technical info about this module. I don't own this module yet.
>>> I foresee to use it in order to mix 1 signal at 10vpp (eurorack level) + 3 signals at 3vpp (line level).
>>> In order to get them output at approximately the same amplitude, I do believe having to attenuate the higher signal around level 4' and the 3 line level fully clockwise. Do you think it would work?
>>> In other terms:
>>> does the attenuator provide an increment of amplitude when the knob is fully clockwise, or simply outputs the original signal level?
>>> Best regards,
>>> FM
