R2M Manual Ribbon controller - 1U row installation
2016-11-13 by Diego Ragnini
2016-11-13 by jaccoville@yahoo.com
Hello,
Try to help but really don't understand your question.Best regardsJacco Ville
Ah, ok... now I understand but still can't give you advise in this. Best regards, Jacco Ville The Netherlands
2016-11-13 by Florian Anwander
Can't help on this too, but I would be interested in the topic in general: How to convert 8HP/ 3U modules to 1U modules. The 8HP is 40.30 mm wide, 1HU is 44.45mm. So one would have to create a new front panel. Am I right?
Am I right?
2016-11-14 by Zoë Blade
Right, you're asking about rackmounting the ribbon controller itself into 1U, not the module it connects to, which is staying 3U and 8HP. I just had a quick look though, and the ribbon controller is slightly longer than a 19" rack is wide, so I don't think it's going to happen. A shame, as on the other axis, it is thin enough to fit the 1U rack height. (You mention cutting it to fit, and I have no idea if it works that way, sorry.) Someone could hypothetically make a 1U ribbon controller (say, with 1V/Oct and gate out, so it's compatible with more than just the one Doepfer module), but I think it would need to be designed that way, rather than cut up. I don't think there'd be much demand for one, and as a one-off it would be quite expensive and/or time consuming to build. I'd settle for having the ribbon controller in front of the rack, on a desk. It's more comfortable at that angle, anyway. Sorry I couldn't help!
2016-11-14 by yahoo@doepfer.de
I'm sorry, this will not work because the position sensor is longer than 19". The active area of the position sensor is 500 mm plus the area required for the connector (~ 70mm). That's more than 19" which is about 483 mm. It's not possible to shorten the positions sensor without damaging the sensor (in contrast to the pressure sensor which can be easily shortened). Best wishes Dieter Doepfer
> Hello, > > is there anybody who tried to ease installation of the manual > onto a 1U eurorack row ? > > Thanks
2016-11-14 by Diego Ragnini
Best wishes
Dieter Doepfer
> Hello,
> Thanks
Then it should be no problem. Simply mount the R2M manual to a 1U blind panel by means of the four M3 threads at the bottom of the R2M manual housing. The lenght of the R2M manual is ~ 600 mm (plus the USB connector). If the width of the case is more it should work. I'd recommend to keep the housing as it guarantees the mechanical stability required for the pressure and position sensors. Best wishes Dieter Doepfer
> -----Ursprüngliche Nachricht----- > Von: Doepfer_a100@yahoogroups.com [mailto:Doepfer_a100@yahoogroups.com] > Gesendet: Montag, 14. November 2016 10:58 > An: Doepfer_a100@yahoogroups.com > Betreff: Re: [Doepfer_a100] R2M Manual Ribbon controller - 1U row > installation > > > > > Thanks, though I imagined a row longer than 84hp, there's some on > sale of 90HP, 104HP, 1 row @ 3U + 1 row @ 1U. I do believe that > Intellijel makes it. Of course, then it would require some work > to manufacture a panel to host the Manual. > > > Best regards, Diego > > > > Il giorno 14/nov/2016, alle ore 10:45, yahoo@doepfer.de > [Doepfer_a100] <Doepfer_a100@yahoogroups.com> ha scritto: > > > > I'm sorry, this will not work because the position sensor is longer than > 19". The active area of the position sensor is 500 mm plus the > area required > for the connector (~ 70mm). That's more than 19" which is about > 483 mm. It's > not possible to shorten the positions sensor without damaging the > sensor (in > contrast to the pressure sensor which can be easily shortened). > > Best wishes > Dieter Doepfer > > > Hello, > > > > is there anybody who tried to ease installation of the manual > > onto a 1U eurorack row ? > > > > Thanks > > > > > > > >
oh yes, I did believe the ribbon being 500 mm, unfortunately the largest intellijel case is 537.3 mm, so I might opt to build a handle wooden top for the A-100LC3 to make the case portable, wider enough for hosting the ribbon and containing left and right small cases for the 2 PSU's. After transport the ribbon can be layered on the top of the case or anywhere else. The only issue would be for hand luggage on planes, typically asking to stay within 55cm length. I thank you a lot for support Best regards Il giorno 14/nov/2016, alle ore 11:10, yahoo@doepfer.de [Doepfer_a100] <Doepfer_a100@yahoogroups.com> ha scritto:
> Then it should be no problem. Simply mount the R2M manual to a 1U blind > panel by means of the four M3 threads at the bottom of the R2M manual > housing. The lenght of the R2M manual is ~ 600 mm (plus the USB connector). > If the width of the case is more it should work. I'd recommend to keep the > housing as it guarantees the mechanical stability required for the pressure > and position sensors. > > Best wishes > Dieter Doepfer > > >> -----Ursprüngliche Nachricht----- >> Von: Doepfer_a100@yahoogroups.com [mailto:Doepfer_a100@yahoogroups.com] >> Gesendet: Montag, 14. November 2016 10:58 >> An: Doepfer_a100@yahoogroups.com >> Betreff: Re: [Doepfer_a100] R2M Manual Ribbon controller - 1U row >> installation >> >> >> >> >> Thanks, though I imagined a row longer than 84hp, there's some on >> sale of 90HP, 104HP, 1 row @ 3U + 1 row @ 1U. I do believe that >> Intellijel makes it. Of course, then it would require some work >> to manufacture a panel to host the Manual. >> >> >> Best regards, Diego >> >> >> >> Il giorno 14/nov/2016, alle ore 10:45, yahoo@doepfer.de >> [Doepfer_a100] <Doepfer_a100@yahoogroups.com> ha scritto: >> >> >> >> I'm sorry, this will not work because the position sensor is longer than >> 19". The active area of the position sensor is 500 mm plus the >> area required >> for the connector (~ 70mm). That's more than 19" which is about >> 483 mm. It's >> not possible to shorten the positions sensor without damaging the >> sensor (in >> contrast to the pressure sensor which can be easily shortened). >> >> Best wishes >> Dieter Doepfer >> >>> Hello, >>> >>> is there anybody who tried to ease installation of the manual >>> onto a 1U eurorack row ? >>> >>> Thanks >> >> >> >> >> >> >> >> > > > > ------------------------------------ > > ------------------------------------ > > > ------------------------------------ > > Yahoo Groups Links > > >
2016-11-26 by ross anderton
Hi,Have you considered building your own case? Clicks And Clocks in Berlin sell 4U frames (a 126HP frame is 646mm wide so the controller will fit easily), if you have basic DIY skills it shouldn't be too difficult.Hope this helps!
Ross
On Monday, November 14, 2016 12:56 PM, "Diego Ragnini diegora@free.fr [Doepfer_a100]" <Doepfer_a100@yahoogroups.com> wrote:
Best regards
> Best wishes
> Dieter Doepfer
>> installation
>> Best regards, Diego
>> area required
>> 483 mm. It's
>> sensor (in
>> Best wishes
>> Dieter Doepfer
>>> Hello,
>>> Thanks
> Yahoo Groups Links
Yahoo Groups Links2016-11-26 by diegora@free.fr
Thanks a lot, I didn't think of it, this advice is much appreciated! Best, Diego Il giorno 26/nov/2016, alle ore 11:51, ross anderton ross_anderton@yahoo.com [Doepfer_a100] < Doepfer_a100@yahoogroups.com > ha scritto: Hi, Have you considered building your own case? Clicks And Clocks in Berlin sell 4U frames (a 126HP frame is 646mm wide so the controller will fit easily), if you have basic DIY skills it shouldn't be too difficult. Hope this helps! Ross On Monday, November 14, 2016 12:56 PM, "Diego Ragnini diegora@free.fr [Doepfer_a100]" < Doepfer_a100@yahoogroups.com > wrote: oh yes, I did believe the ribbon being 500 mm, unfortunately the largest intellijel case is 537.3 mm, so I might opt to build a handle wooden top for the A-100LC3 to make the case portable, wider enough for hosting the ribbon and containing left and right small cases for the 2 PSU's. After transport the ribbon can be layered on the top of the case or anywhere else. The only issue would be for hand luggage on planes, typically asking to stay within 55cm length. I thank you a lot for support Best regards Il giorno 14/nov/2016, alle ore 11:10, yahoo@doepfer.de [Doepfer_a100] < Doepfer_a100@yahoogroups.com > ha scritto: > Then it should be no problem. Simply mount the R2M manual to a 1U blind > panel by means of the four M3 threads at the bottom of the R2M manual > housing. The lenght of the R2M manual is ~ 600 mm (plus the USB connector). > If the width of the case is more it should work. I'd recommend to keep the > housing as it guarantees the mechanical stability required for the pressure > and position sensors. > > Best wishes > Dieter Doepfer > > >> -----Ursprüngliche Nachricht----- >> Von: Doepfer_a100@yahoogroups.com [mailto: Doepfer_a100@yahoogroups.com ] >> Gesendet: Montag, 14. November 2016 10:58 >> An: Doepfer_a100@yahoogroups.com >> Betreff: Re: [Doepfer_a100] R2M Manual Ribbon controller - 1U row >> installation >> >> >> >> >> Thanks, though I imagined a row longer than 84hp, there's some on >> sale of 90HP, 104HP, 1 row @ 3U + 1 row @ 1U. I do believe that >> Intellijel makes it. Of course, then it would require some work >> to manufacture a panel to host the Manual. >> >> >> Best regards, Diego >> >> >> >> Il giorno 14/nov/2016, alle ore 10:45, yahoo@doepfer.de >> [Doepfer_a100] < Doepfer_a100@yahoogroups.com > ha scritto: >> >> >> >> I'm sorry, this will not work because the position sensor is longer than >> 19". The active area of the position sensor is 500 mm plus the >> area required >> for the connector (~ 70mm). That's more than 19" which is about >> 483 mm. It's >> not possible to shorten the positions sensor without damaging the >> sensor (in >> contrast to the pressure sensor which can be easily shortened). >> >> Best wishes >> Dieter Doepfer >> >>> Hello, >>> >>> is there anybody who tried to ease installation of the manual >>> onto a 1U eurorack row ? >>> >>> Thanks >> >> >> >> >> >> >> >> > > > > ------------------------------------ > > ------------------------------------ > > > ------------------------------------ > > Yahoo Groups Links > > > ------------------------------------ ------------------------------------ ------------------------------------ Yahoo Groups Links
