Doepfer
OH NO!!!!!
OH NO!!!!!
2002-12-14 by kali_the_black <poictesme@earthlink.net>
Help! Um, I was just programming away on my a100 and all of a sudden
without cause or warning I lost all power!!!! where's the fuse?
Anyone know what the heck might have caused this? Someone help
please!!!????
Ben
Re: OH NO!!!!!
2002-12-14 by Tim Stinchcombe <timothy@tstinchcombe.freeserve.co.uk>
Hi Ben,
sudden
> please!!!????
Take the plug out of the back of the case. Immediately above the
where the plug fits is where the fuse is, you'll need to lever it out
with a screwdriver or the like, from underneath. The fuses are not
ordinary 13-amp plug types, but special 'time-lag' ones. (It would be
as well to check the one in the plug too, to see which has blown.)
Maplin sell the time-lag ones, so I'm sorry to say you will probably
not get it going again straight away - use the time to try and
establish what happened(!). If it's not an obvious wayward piece of
metal shorting something across one of the boards, then it's hard to
suggest what it might be - generally all modules have short circuit
protection built in, because the very act of inserting patch leads
tends to short things momentarily to ground, so it's unlikely to be a
loose or dangling lead. You could try taking your current patch apart
lead-by-lead to see if you might have wired up something in a non-
nice way (though again this Doepfer stuff seems pretty unburstable
from that point of view, so I think this is very unlikely). The only
time it happened to me is when I was using it power something on a
breadboard - I connected an op amp the wrong way - and it blew the
fuse in short order (chip still seemed to work though!).
Tim
Re: OH NO!!!!!
Ok, I replaced the fuse in the power plug and all is good again, but
Doug at En-port (u.s. retailer and representative) told me to use a
fast blow fuse. You say slow blow type. Anyone else have input or
know where I can find the spec? I looked on the doepfer site but it
didnt' really say when I looked at the power supply manual page.
I'm going to wait until I get responses to get back to programming.
Time to watch a movie! :)
and yea. first things I did were to unplug power and patch leads...
just makes a guy panic when his favorite synth tells him NO!
thanks alot.
ben
--- In Doepfer_a100@yahoogroups.com, "Tim Stinchcombe <timothy@t...>"
out
be
probably
to
a
apart
only
> Tim
Re: OH NO!!!!!
Hi Ben,
but
Ah ha, I didn't realise you were in the States! However, I'm amazed
it was the fuse in the plug. Since you use a lower mains voltage over
there I don't know what typical ratings of mains fuses you get. In
the UK we generally get 13, 5 and 1 amp fuses (for 250V AC). The fuse
in the 'power receptacle' on the back of G6 case as I mentioned is
rated at 250V and 100mA, i.e. 0.1 amps, which on the face of it
appears to be *substantially* lower than those that might be in the
plug. It is this fuse which is a 'time-lag' fuse - at least that is
what it says on the box of replacements I got when I blew one of
mine, and they look *identical* to the one I blew, even down to what
looks like the manufacturer's stamp on them. I too cannot find
anything in either the manual or the website, although when mine
blew, I feel certain I found something somewhere, because like you I
was extremely cautious (until I discovered the reversed op amp...)
So, none of this really helps anyway because all the fuse values are
likely to be diferent where you are, although you could prise out the
one in your case to see what it is marked as (?).
Tim
Re: OH NO!!!!!
2002-12-14 by (i think you can figure that out) <petergrenader@hotmail.com>
The fuses are not
time lag = SLO BLO = slow blow fuses.  You can get these at any
electronics store.  In the US most hardware srtores will sell them
as well.
Re: OH NO!!!!!
Normal fuses (here referred to as FAST BLO are safer.  They go
quickly - so if something serious happens chances are the fuse
will go beforew the spike or whatever it is that's serging through
the systems doesn't do damage for those short moments before
the slo blo blows.
My suggestion:  just get a few of the correct value in fast blow.
This way, if something happens and they go, you've got them on
hand and back up in minutes.
Re: [Doepfer_a100] Re: OH NO!!!!!
2002-12-16 by Florian Anwander
Hi
The fuse is only(!) there to prevent Powersupply hazards. If the
powersupply itself produces wrong voltages you have no chance - as far as I
remember the Doepfer powersupply does not have any fuses on the low voltage
side.
The slow blowing fuse makes sense, since the main current is drawn while
switching on the A-100 when the capacitors in the powersupply are loaded.
This short hogher current should be survived and do not harm the
transformer. But continuous too high currents might damage the transformer.
Only these currents will blow the fuse.
just my 2c'
Florian
