Doepfer
Re: [Doepfer_a100] Single note Vs Continuous Oscillation
2017-02-06 by Diego Ragnini
try always to “discuss” patches suggested somewhere, instead of simply plugging while visually copying, you might find “examples” reporting oversights. Is the case of the 1st of the Application Examples printed into the A-190-4 manual at page 20:
You always have to think in terms of source&destination:
the wasp filter out (source) must be plugged to the 1st VCA input (destination)
as well as the 1st VCA out must be plugged to the 2nd VCA input
so the two yellow cables (starting from right) are misplaced in the picture
If you are at ease with english and reading - and want to give yourself a better basis for the modular thing - search for the second edition of this book
Allen Strange, Electronic Music: systems, techniques and controls
there's should be a couple of editions available on the web
Il giorno 06/feb/2017, alle ore 20:53, "Colum Brady colum@bradys.eu [Doepfer_a100]" <Doepfer_a100@yahoogroups.com> ha scritto:
Success - thanks again to All for great feedback.
Colum
oh yep, indeed I browsed a pdf version downloaded long ago, thanks for notifying!
Il giorno 06/feb/2017, alle ore 21:45, Florian Anwander fanwander@mnet-online.de [Doepfer_a100] <Doepfer_a100@yahoogroups.com> ha scritto:
Ouch! It looks like this is an old graphic. The 142-3 is wired wrongly: at the upper VCA the in and out should be interchanged. In the pdf that is online (http://www.doepfer.de/a100_man/A190_4_man.pdf), the graphic is corrected.
Florian
