Doepfer
New member introduction
2017-03-25 by Tim Burgess
I’m UK-based and been using synths since the early 80s. I got my first LC9 case about a year ago and added a G6 a couple of months back.
I got some good advice right at the start and decided that I wanted to design my modular in 2 phases:
1 – I wanted a compositional tool that didn’t require a computer, but could take advantage of my DAW for production of anything I managed to create that would be worth polishing;
2 – A tool to allow me to learn more about sound design above and beyond what I can achieve with my existing keyboards.
I’m pretty much at the end of phase 1 – I only need to address the beginner’s mistake of not buying enough mults. I have an Arturia BeatStep Pro that acts as the master clock. This controls an Atlantis, a Mother-32 and a Little Drummer Boy 2 via its CV/gate/trigger outputs. It also provides MIDI clock to my Kurzweil K2600, which provides polyphonic sequencing for my MIDI-equipped keys. I also pass the clock along to an A-155 Trigger Sequencer and a Turing Machine MkII to provide extra sequencing. The rest of my A-100 rig is:
A-101.3 Vactral Phaser
A-106.5 SEM Filter
A-110.1 Standard VCO
A-114 Dual Ring Modulator
A-119 Envelope follower
A-131 Voltage-Controlled Amplifier
A-138B Audio Mixer
2 x A-138D Cross-fader/FX Insert
A-156 Dual Quantizer
A-160.2 Clock Divider 2
A-166 Dual Logic module
A-180.2 Multi-Jack (2HP)
A-188.1D 4096-stage Bucket Brigade Delay
The oscillator, filter and VCA were my first modules, along with the effects modules (just because I fancied them). I’ve only recently acquired the quantizer and clocck dividers that have made the whole rig come alive. I’ve also got a 4MS rotating clock divider and its break-out module, a Pittsburgh Modular Outs for headphone use, an Expert Sleeppers FH-1 for USB MIDI input and the Expert Sleepers ES-3/ES-6 combination for DAW I/O (though I have an audio clicking problem with the ES-6 at the moment).
It might be worth me pointing out that I ad another set of requirements, based on accessibility. I’m totally blind and have progressive arthritis in my hands, so I needed to pick things carefully in order to ensure that I could take full advantage of each module. For example, I picked the FH-1 because it had direct support for my LinnStrument (which is kinder to my hands than my traditional keyboards) and because it can be configured by writing a script file, placing it on a USB drive then powering up the module with the drive inserted. I’m a software developer in my day job, so doing this doesn’t frighten me.
I’ve had wonderful support from Mr. Doepfer, who has provided text descriptions of panel layouts and from everybody I’ve talked/mailed/forumed with in the modular community, which has given me (almost) as much pleasure as interacting with the synth itself.
Anyway, if you got this far, apologies for rambling on and I hope that this was of some little interest.
Best wishes.
Tim Burgess
RE: [Doepfer_a100] New member introduction
Well, there’s a massive side-benefit. It keeps me out of my wife’s hair:)
Best wishes.
Tim Burgess
From: Doepfer_a100@yahoogroups.com [mailto:Doepfer_a100@yahoogroups.com]
Sent: Saturday, March 25, 2017 1:14 PM
Subject: Re: [Doepfer_a100] New member introduction
Indeed welcome, tnx for your joyful entry.
Reminds me of the fun, financial planning and headaches the modular world gives me. 😄
Jacco Ville
The Netherlands
Sent from my IPhone.
Op 25 mrt. 2017 om 13:55 heeft Bakis Sirros synth_freak_2000@yahoo.com <mailto:synth_freak_2000@yahoo.com>  [Doepfer_a100] <Doepfer_a100@yahoogroups.com <mailto:Doepfer_a100@yahoogroups.com> > het volgende geschreven:
Welcome aboard Tim! i hope you'll find this group helpful in your modular-music quest.
best regards,
Bakis.
Bakis Sirros - Parallel Worlds | [Doepfer_a100] group owner | www. parallel - worlds - music. com | www. facebook. com/ parallelworldsmusic |  www. DiN. org. uk
  _____
From: "'Tim Burgess' tim@raisedbar.net <mailto:tim@raisedbar.net>  [Doepfer_a100]" <Doepfer_a100@yahoogroups.com <mailto:Doepfer_a100@yahoogroups.com> >
To: doepfer_a100@yahoogroups.com <mailto:doepfer_a100@yahoogroups.com>
Sent: Saturday, March 25, 2017 1:52 PM
Subject: [Doepfer_a100] New member introduction
A-106.5 SEM Filter
A-138B Audio Mixer
Best wishes.
Tim Burgess
I’m sure I will.
Apart from the mults, I’m placing an embargo on further module purchases until I’ve got a good handle on using what I’ve got already. I’m usually quite bad at putting limits on my enthusiasms, but I know that uncontrolled expansion is not the way to progress with this stuff, either technically or artistically.
Best wishes.
Tim Burgess
Sent: Saturday, March 25, 2017 12:56 PM
best regards,
Bakis.
  _____
From: "'Tim Burgess' tim@raisedbar.net [Doepfer_a100]" <Doepfer_a100@yahoogroups.com>
A-106.5 SEM Filter
A-138B Audio Mixer
Best wishes.
Tim Burgess
2017-03-25 by Bakis Sirros
best regards,Bakis.
    Hi,  I’m UK-based and been using synths since the early 80s. I got my first LC9 case about a year ago and added a G6 a couple of months back.  I got some good advice right at the start and decided that I wanted to design my modular in 2 phases:  1 – I wanted a compositional tool that didn’t require a computer, but could take advantage of my DAW for production of anything I managed to create that would be worth polishing;  2 – A tool to allow me to learn more about sound design above and beyond what I can achieve with my existing keyboards.  I’m pretty much at the end of phase 1 – I only need to address the beginner’s mistake of not buying enough mults. I have an Arturia BeatStep Pro that acts as the master clock. This controls an Atlantis, a Mother-32 and a Little Drummer Boy 2 via its CV/gate/trigger outputs. It also provides MIDI clock to my Kurzweil K2600, which provides polyphonic sequencing for my MIDI-equipped keys. I also pass the clock along to an A-155 Trigger Sequencer and a Turing Machine MkII to provide extra sequencing. The rest of my A-100 rig is:  A-101.3 Vactral PhaserA-106.5 SEM FilterA-110.1 Standard VCOA-114 Dual Ring ModulatorA-119 Envelope followerA-131 Voltage-Controlled AmplifierA-138B Audio Mixer2 x A-138D Cross-fader/FX InsertA-156 Dual QuantizerA-160.2 Clock Divider 2A-166 Dual Logic moduleA-180.2 Multi-Jack (2HP)A-188.1D 4096-stage Bucket Brigade Delay  The oscillator, filter and VCA were my first modules, along with the effects modules (just because I fancied them). I’ve only recently acquired the quantizer and clocck dividers that have made the whole rig come alive. I’ve also got a 4MS rotating clock divider and its break-out module, a Pittsburgh Modular Outs for headphone use, an Expert Sleeppers FH-1 for USB MIDI input and the Expert Sleepers ES-3/ES-6 combination for DAW I/O (though I have an audio clicking problem with the ES-6 at the moment).  It might be worth me pointing out that I ad another set of requirements, based on accessibility. I’m totally blind and have progressive arthritis in my hands, so I needed to pick things carefully in order to ensure that I could take full advantage of each module. For example, I picked the FH-1 because it had direct support for my LinnStrument (which is kinder to my hands than my traditional keyboards) and because it can be configured by writing a script file, placing it on a USB drive then powering up the module with the drive inserted. I’m a software developer in my day job, so doing this doesn’t frighten me.  I’ve had wonderful support from Mr. Doepfer, who has provided text descriptions of panel layouts and from everybody I’ve talked/mailed/forumed with in the modular community, which has given me (almost) as much pleasure as interacting with the synth itself.  Anyway, if you got this far, apologies for rambling on and I hope that this was of some little interest.  Best wishes.  Tim Burgess    #yiv7208264015 #yiv7208264015 -- #yiv7208264015ygrp-mkp {border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;}#yiv7208264015 #yiv7208264015ygrp-mkp hr {border:1px solid #d8d8d8;}#yiv7208264015 #yiv7208264015ygrp-mkp #yiv7208264015hd {color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;}#yiv7208264015 #yiv7208264015ygrp-mkp #yiv7208264015ads {margin-bottom:10px;}#yiv7208264015 #yiv7208264015ygrp-mkp .yiv7208264015ad {padding:0 0;}#yiv7208264015 #yiv7208264015ygrp-mkp .yiv7208264015ad p {margin:0;}#yiv7208264015 #yiv7208264015ygrp-mkp .yiv7208264015ad a {color:#0000ff;text-decoration:none;}#yiv7208264015 #yiv7208264015ygrp-sponsor #yiv7208264015ygrp-lc {font-family:Arial;}#yiv7208264015 #yiv7208264015ygrp-sponsor #yiv7208264015ygrp-lc #yiv7208264015hd {margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;}#yiv7208264015 #yiv7208264015ygrp-sponsor #yiv7208264015ygrp-lc .yiv7208264015ad {margin-bottom:10px;padding:0 0;}#yiv7208264015 #yiv7208264015actions {font-family:Verdana;font-size:11px;padding:10px 0;}#yiv7208264015 #yiv7208264015activity {background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}#yiv7208264015 #yiv7208264015activity span {font-weight:700;}#yiv7208264015 #yiv7208264015activity span:first-child {text-transform:uppercase;}#yiv7208264015 #yiv7208264015activity span a {color:#5085b6;text-decoration:none;}#yiv7208264015 #yiv7208264015activity span span {color:#ff7900;}#yiv7208264015 #yiv7208264015activity span .yiv7208264015underline {text-decoration:underline;}#yiv7208264015 .yiv7208264015attach {clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;}#yiv7208264015 .yiv7208264015attach div a {text-decoration:none;}#yiv7208264015 .yiv7208264015attach img {border:none;padding-right:5px;}#yiv7208264015 .yiv7208264015attach label {display:block;margin-bottom:5px;}#yiv7208264015 .yiv7208264015attach label a {text-decoration:none;}#yiv7208264015 blockquote {margin:0 0 0 4px;}#yiv7208264015 .yiv7208264015bold {font-family:Arial;font-size:13px;font-weight:700;}#yiv7208264015 .yiv7208264015bold a {text-decoration:none;}#yiv7208264015 dd.yiv7208264015last p a {font-family:Verdana;font-weight:700;}#yiv7208264015 dd.yiv7208264015last p span {margin-right:10px;font-family:Verdana;font-weight:700;}#yiv7208264015 dd.yiv7208264015last p span.yiv7208264015yshortcuts {margin-right:0;}#yiv7208264015 div.yiv7208264015attach-table div div a {text-decoration:none;}#yiv7208264015 div.yiv7208264015attach-table {width:400px;}#yiv7208264015 div.yiv7208264015file-title a, #yiv7208264015 div.yiv7208264015file-title a:active, #yiv7208264015 div.yiv7208264015file-title a:hover, #yiv7208264015 div.yiv7208264015file-title a:visited {text-decoration:none;}#yiv7208264015 div.yiv7208264015photo-title a, #yiv7208264015 div.yiv7208264015photo-title a:active, #yiv7208264015 div.yiv7208264015photo-title a:hover, #yiv7208264015 div.yiv7208264015photo-title a:visited {text-decoration:none;}#yiv7208264015 div#yiv7208264015ygrp-mlmsg #yiv7208264015ygrp-msg p a span.yiv7208264015yshortcuts {font-family:Verdana;font-size:10px;font-weight:normal;}#yiv7208264015 .yiv7208264015green {color:#628c2a;}#yiv7208264015 .yiv7208264015MsoNormal {margin:0 0 0 0;}#yiv7208264015 o {font-size:0;}#yiv7208264015 #yiv7208264015photos div {float:left;width:72px;}#yiv7208264015 #yiv7208264015photos div div {border:1px solid #666666;height:62px;overflow:hidden;width:62px;}#yiv7208264015 #yiv7208264015photos div label {color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}#yiv7208264015 #yiv7208264015reco-category {font-size:77%;}#yiv7208264015 #yiv7208264015reco-desc {font-size:77%;}#yiv7208264015 .yiv7208264015replbq {margin:4px;}#yiv7208264015 #yiv7208264015ygrp-actbar div a:first-child {margin-right:2px;padding-right:5px;}#yiv7208264015 #yiv7208264015ygrp-mlmsg {font-size:13px;font-family:Arial, helvetica, clean, sans-serif;}#yiv7208264015 #yiv7208264015ygrp-mlmsg table {font-size:inherit;font:100%;}#yiv7208264015 #yiv7208264015ygrp-mlmsg select, #yiv7208264015 input, #yiv7208264015 textarea {font:99% Arial, Helvetica, clean, sans-serif;}#yiv7208264015 #yiv7208264015ygrp-mlmsg pre, #yiv7208264015 code {font:115% monospace;}#yiv7208264015 #yiv7208264015ygrp-mlmsg * {line-height:1.22em;}#yiv7208264015 #yiv7208264015ygrp-mlmsg #yiv7208264015logo {padding-bottom:10px;}#yiv7208264015 #yiv7208264015ygrp-msg p a {font-family:Verdana;}#yiv7208264015 #yiv7208264015ygrp-msg p#yiv7208264015attach-count span {color:#1E66AE;font-weight:700;}#yiv7208264015 #yiv7208264015ygrp-reco #yiv7208264015reco-head {color:#ff7900;font-weight:700;}#yiv7208264015 #yiv7208264015ygrp-reco {margin-bottom:20px;padding:0px;}#yiv7208264015 #yiv7208264015ygrp-sponsor #yiv7208264015ov li a {font-size:130%;text-decoration:none;}#yiv7208264015 #yiv7208264015ygrp-sponsor #yiv7208264015ov li {font-size:77%;list-style-type:square;padding:6px 0;}#yiv7208264015 #yiv7208264015ygrp-sponsor #yiv7208264015ov ul {margin:0;padding:0 0 0 8px;}#yiv7208264015 #yiv7208264015ygrp-text {font-family:Georgia;}#yiv7208264015 #yiv7208264015ygrp-text p {margin:0 0 1em 0;}#yiv7208264015 #yiv7208264015ygrp-text tt {font-size:120%;}#yiv7208264015 #yiv7208264015ygrp-vital ul li:last-child {border-right:none !important;}#yiv7208264015
2017-03-25 by Jacco Ville
Jacco Ville
The Netherlands
> Op 25 mrt. 2017 om 13:55 heeft Bakis Sirros synth_freak_2000@yahoo.com [Doepfer_a100] <Doepfer_a100@yahoogroups.com> het volgende geschreven:
> best regards,
> Bakis.
> Hi,
> A-106.5 SEM Filter
> A-138B Audio Mixer
> Best wishes.
> Tim Burgess
