Doepfer
adjusting a1434 VCLFO
2018-03-14 by Floris V.
Dear, my Doepfer a1434 VCLFO cycles between -5 volts and +5 volts,
would it be possible to have it cycling between 0 volts and +5volts?
Or between 0 volts and +10 volts?
Should I try the "offset" and "scale" trimpots on the pcb?
http://www.doepfer.de/A100_pictures/doepfer_a143_4.jpg
http://www.doepfer.de/a1434.htm
Thanks!
Floris
Re: [Doepfer_a100] adjusting a1434 VCLFO
2018-03-15 by Nicholas Keller
Scale and offset is for the 1V/Oct control response, you don't want to touch those.
I don't see jumpers on the boards for DC offset or rectifying, so you would need to modify.....or stick an offset/attenuator module on each of the outputs that require one.
http://www.doepfer.de/a1832.htm
> On Mar 14, 2018, at 7:25 PM, 'Floris V.' florisvanhoof@ecomail.org [Doepfer_a100] <Doepfer_a100@yahoogroups.com> wrote:
> Thanks!
> Floris
AW: [Doepfer_a100] adjusting a1434 VCLFO
2018-03-15 by yahoo@doepfer.de
> Thanks!
> Floris
It's not possible to shift the output voltage range of the A-143-4 to
0...+10V. For this an external module (e.g. A-183-2) is required. Do not
change the offset and scale trimming as this will affect only the frequency
scale and frequency offset.
Best wishes
Dieter Doepfer
Re: AW: [Doepfer_a100] adjusting a1434 VCLFO
2018-03-15 by 2206rec@gmail.com
One more idea would involve the "direction inputs" on the a1434 VCLFO
Would it be possible to make it so that when the VCLFO is on 0v he resets and changes direction automatically and always stays above 0v?
AW: AW: [Doepfer_a100] adjusting a1434 VCLFO
> as 4 offset generators would be too big and expensive for this
> project, would it be possible to modify one Doepfer A-138c
> polarizing mixer so I can offset each of the 4 outputs of the
> Quad VCLFO individually?
> http://www.doepfer.de/a138c.htm
I'm sorry - it's not possible to modify the A-138c in an easy way to work as
an offset generator.
Best wishes
Dieter Doepfer
> it will only be used with 4 Velleman K8064 DC controlled dimmers
> Maybe it's easier to modify the dimmer ciruits
> https://www.velleman.eu/downloads/0/illustrated/illustrated_assemb
> ly_manual_k8064.pdf
> All the best
> Floris
If you are familiar with electronics that's possible (adding a positive
voltage via another 4k7 resistor to the junction of R16 and D4).
But as the dimmers include parts, terminals and pcb tracks that are
connected to mains voltage I'd strictly disadvise against this modification
! Otherwise there is danger to life and you may damage the A-143-4 or even
more.
Best wishes
Dieter Doepfer
This would require four external comparators (e.g. A-167) and is more effort
than the usage of the offset generators A-183-2.
Best wishes
Dieter Doepfer
