Doepfer
A simple patch with the A-119 Ext.Input/Env.Follower
2018-05-18 by Diego Ragnini
Hello everybody,
Hope someone can help me somehow
I have a simple patch involving this module:
A mult signal from electric rhythmic guitar (muted peaks: extremely transient short envelopes) feeds the module to create gates which in turn are used to trigger MI Rings. The problem - it seems to me - is that a further gate is not created until the previous guitar peak is not completely “silenced”… : of course, the module cannot generate a new gate until the previous is HIGH…
I had tried to manage the thing by the means of the threshold knob but it doesn’t solve (and this is strange)… Anybody any hint please?
I do believe the module includes a comparator at the threshold stage: should I try using another comparator in the patch?
Best regards, Diego
Re: [Doepfer_a100] A simple patch with the A-119 Ext.Input/Env.Follower
2018-05-18 by Jacco Ville
Maybe use a noisegate in front of the A119?
Sent from my IPhone.
> Op 18 mei 2018 om 07:40 heeft Diego Ragnini diegora@free.fr [Doepfer_a100] <Doepfer_a100@yahoogroups.com> het volgende geschreven:
> Hello everybody,
> Best regards, Diego
Thank you Jacco
I don’t own a pedal noise gate, is there any in eurorack format? Though probably it will not be too different from a comparator + a kind of logic module...
> Il giorno 18 mag 2018, alle ore 08:05, Jacco Ville jaccoville@yahoo.com [Doepfer_a100] <Doepfer_a100@yahoogroups.com> ha scritto:
> Op 18 mei 2018 om 07:40 heeft Diego Ragnini diegora@free.fr <mailto:diegora@free.fr> [Doepfer_a100] <Doepfer_a100@yahoogroups.com <mailto:Doepfer_a100@yahoogroups.com>> het volgende geschreven:
>> Hello everybody,
>> Best regards, Diego
AW: [Doepfer_a100] A simple patch with the A-119 Ext.Input/Env.Follower
2018-05-18 by yahoo@doepfer.de
Hello,
in principle it should work. As you suppose the gate is simply derived from
the envelope signal by means of a comparator with adjustable threshold. I'd
recommend to set the threshold fully clockwise (max. threshold value, about
+9V) and then reduce the gain until the gate output behaves as desired.
Best wishes
Dieter Doepfer
> Von: Doepfer_a100@yahoogroups.com [mailto:Doepfer_a100@yahoogroups.com]
> Gesendet: Freitag, 18. Mai 2018 07:41
> Betreff: [Doepfer_a100] A simple patch with the A-119
> Hello everybody,
> Best regards, Diego
> Posted by: Diego Ragnini <diegora@free.fr>
> Yahoo Groups Links
Thanks a lot Dieter
I will try the way you say
Best regards,
dxx
> Il giorno 18 mag 2018, alle ore 11:04, yahoo@doepfer.de [Doepfer_a100] <Doepfer_a100@yahoogroups.com> ha scritto:
> Hello,
> Best wishes
> Dieter Doepfer
>> Hello everybody,
>> Best regards, Diego
>> Yahoo Groups Links
> Yahoo Groups Links
Sorry Dieter, is the hysteresis concerned by this situation?
> Hello,
> Best wishes
> Dieter Doepfer
>> Hello everybody,
>> Best regards, Diego
>> Yahoo Groups Links
> Yahoo Groups Links
2018-05-22 by yahoo@doepfer.de
The hysteresis of the A-119 comparator is fixed (defined by the resistor
R28) and cannot be changed like the A-167 which has a Gap control.
Best wishes
Dieter Doepfer
> Gesendet: Samstag, 19. Mai 2018 00:31
> Betreff: Re: [Doepfer_a100] A simple patch with the A-119
> > Hello,
> derived from
> threshold. I'd
> value, about
> > Best wishes
> > Dieter Doepfer
> >> Hello everybody,
> hint please?
> >> Best regards, Diego
> >> Yahoo Groups Links
> > Yahoo Groups Links
> Yahoo Groups Links
2018-05-23 by Diego Ragnini
Okay, thanks again !
> Il giorno 22 mag 2018, alle ore 11:42, yahoo@doepfer.de [Doepfer_a100] <Doepfer_a100@yahoogroups.com> ha scritto:
> Best wishes
> Dieter Doepfer
