Re: about the a131,a130 output difference!
2003-01-09 by Tim Stinchcombe <timothy@tstinchcombe.freeserve.co.uk>
> i think,first of all ,you have to check that the two > vca's that you have(a131,a130) are of the same > version!if they are,then you just plug the output of > the same vco(a110) to the input of the a131,a130 and > turn both their inputs and outputs knobs to 10 and > their gains to 10!then they should output the a110 > waveform with the same volume.if you hear a > considerable difference in ouput volume between the > two vca's then it's time to email doepfer!so,florian > IS right! Well done Bakis - I had overlooked the possiblity that the older 131 could have had a similar output to the the 130 (I don't have one). Sincerest apologies to Florian if this is what he has in his set-up! (All my previous comments apply to A-130, v2 1996 and A-131, v2 2001.) Tim
