A-143-2 problem
2019-07-05 by karelvanbezooijen@yahoo.com
2019-07-05 by yahoo@doepfer.de
I'm sorry about the problems with the module. Maybe one or more of the diodes and/or transistors are defective. If you cannot fix the the problem please follow the repair notes on the FAQ page of our website: www.doepfer.com > English > FAQ > General > Repair procedure Best wishes Dieter Doepfer
> -----Ursprüngliche Nachricht----- > Von: Doepfer_a100@yahoogroups.com [mailto:Doepfer_a100@yahoogroups.com] > Gesendet: Freitag, 5. Juli 2019 07:14 > An: Doepfer_a100@yahoogroups.com > Betreff: [Doepfer_a100] A-143-2 problem > > While using one of the EG of this module all of a sudden it did not function > well anymore. None of the pots has any influence on the envelope. The attack > stays at max. I already replaced both TL084 and CMOS555 but that didn't solve > anything. The other three still work fine. Any suggestions are more than > welcome. > > Best regards, > Karel
2019-07-06 by karelvanbezooijen@yahoo.com
2019-07-06 by man.of.mystery@ntlworld.com
2019-07-06 by swalker@fraserwalkerltd.co.uk
Hi Karel I can certainly endorse the electrolytics as the first component to check. I had a faulty dx7II. Wouldn’t switch on. I replaced all the electrolytic capacitors on the power board. Cost me less than 5 Euros. Works like new now. Stu
From: Doepfer_a100@yahoogroups.com <Doepfer_a100@yahoogroups.com> Sent: 06 July 2019 13:24 To: Doepfer_a100@yahoogroups.com Subject: [Doepfer_a100] Re: A-143-2 problem Karel, Electrolytic capacitors are probably the shortest lived of all components in common use, so I'd always suspect those first. I've never seen an A-143-2, but I've found a good image of one on schneidersladen.de, via a google image search. I see what looks like four identical boards, with at least two electrolytic capacitors each. You might be able to spot the difference between the capacitors on the faulty board and the others, but not necessarily. Sometimes you can see damage, but not always. You could desolder them and measure their capacitance, but a lot of meters give false readings on faulty ones - they tend to show a higher value, when the ESR increases. They are mostly quite cheap to replace, so it may be better to just try that first. If there are any tantalum bead capacitors, those can be damaged by reverse voltage, but otherwise are more robust. - Andy
2019-07-07 by karelvanbezooijen@yahoo.com
2019-07-07 by Steven Jenkins
Dodgy cable ? I’ve had more than the odd patch cable fail/have a poor connection/loose joint. Just a thought. Steve Out of office - sent from mobile device
> On 7 Jul 2019, at 20:31, karelvanbezooijen@yahoo.com [Doepfer_a100] <Doepfer_a100@yahoogroups.com> wrote: > > I checked the board. > M - position uses 100n Film + 2u2u electrolytic > L - position uses 100n Film > H - position uses 100n Film + 100u electrolytic > > As the envelope attack stayed long in every position it couldn't be the electrolytic caps I guess. > > I tried to measure the diodes but the boards are too close to each other to measure every one of them. Disassembling is not easy. > > Anyway I put the module back in the case. > > Surprised I was to notice that it works again! Am I happy? Yes. Am I satisfied? No, because I don't know what was wrong. > > Karel. >
2019-07-07 by man.of.mystery@ntlworld.com
2019-07-08 by karelvanbezooijen@yahoo.com
2019-07-08 by yahoo@doepfer.de
I don't think that it's a problem of the electrolytic capacitors because in the center position of the range switch no electrolytic capacitors are involved. Only in the upper and lower position of the range switch electrolytic capacitors are used as timing capacitors. In the center position a foil capacitor is used and I don't think that it's damaged. Best wishes Dieter Doepfer
> -----Ursprüngliche Nachricht----- > Von: Doepfer_a100@yahoogroups.com [mailto:Doepfer_a100@yahoogroups.com] > Gesendet: Sonntag, 7. Juli 2019 05:38 > An: Doepfer_a100@yahoogroups.com > Betreff: [Doepfer_a100] Re: A-143-2 problem > > Thank you all for the replies. Checking the capacitors seems the easiest > option. As switching between M-L-H position doesn't have any effect on the > envelope maybe one of them is defect. The one that is in all signal paths. > > Karel.
2019-07-11 by karelvanbezooijen@yahoo.com
