Re: some info on VACTROL modules from doepfer.
2003-04-03 by ethanzer0
--- In Doepfer_a100@yahoogroups.com, Bakis Sirros <synth_freak_2000@y...> wrote: > DIETER SAY: > "I will rummage for my old documents as I made some > vactrol designs about 20 years ago (filters, phasers, If anybody is interested, there is the buchla vactrol based low-pass gate: http://www.buzzclick-music.com/lowpassgate.jpg That is from peter grenader's DIY pages. Enjoy! Ethan
2003-04-03 by code_pig
Bakis, Pass on to Dieter that the Fender Rhodes and Fender amplifiers use LDR's for their tremelo, and the LDP's are completely sealed units. Might they be of some use? Regards, Kevin --- In Doepfer_a100@yahoogroups.com, Bakis Sirros <synth_freak_2000@y...> wrote:
> DIETER SAY: > "I will rummage for my old documents as I made some > vactrol designs about 20 years ago (filters, phasers, > a guitar "vibrato", VCA). One was a triple filter with > a separate LFO for each filter similar to the A-127 > and was called "grawler" (don't ask why I choose that > name). Another was a VC phaser similar to A-125 but > with 10 vactrols instead of the FETs of the A-125. I > can remember that it was a little bit a problem to > protect the LDRs (light depending resistors) from > light not coming from the corresponding LEDs resp. > bulbs. As far as I know each LED/LDR combination was > protected by a cap and the cap as well as the pcb area > below the LED/LDR were painted with black color to > seal the device against light from outside. But no > problems that we could no solve. Only a little bit > labor-intensive. > Best wishes > Dieter Doepfer" > > > > > > ===== > synthfreak(parallel worlds) > athens-greece > [Doepfer_a100] group owner-moderator > > __________________________________________________ > Do you Yahoo!? > Yahoo! Tax Center - File online, calculators, forms, and more > http://tax.yahoo.com
2003-04-03 by Bakis Sirros
DIETER SAY: "I will rummage for my old documents as I made some vactrol designs about 20 years ago (filters, phasers, a guitar "vibrato", VCA). One was a triple filter with a separate LFO for each filter similar to the A-127 and was called "grawler" (don't ask why I choose that name). Another was a VC phaser similar to A-125 but with 10 vactrols instead of the FETs of the A-125. I can remember that it was a little bit a problem to protect the LDRs (light depending resistors) from light not coming from the corresponding LEDs resp. bulbs. As far as I know each LED/LDR combination was protected by a cap and the cap as well as the pcb area below the LED/LDR were painted with black color to seal the device against light from outside. But no problems that we could no solve. Only a little bit labor-intensive. Best wishes Dieter Doepfer" ===== synthfreak(parallel worlds) athens-greece [Doepfer_a100] group owner-moderator __________________________________________________ Do you Yahoo!? Yahoo! Tax Center - File online, calculators, forms, and more http://tax.yahoo.com
