Doepfer
A127 mod
A127 mod
2003-04-09 by pstnotpd
Would it be feasible to make a mod on the A127 so I kan switch the
filter and the mixer settings from the front panel? I'm thinking of 4
standard switches somewhere next to the outputs. As far as I can
figure out I would only have to change the dipswitches to some kind
of 3 way plug connected to 3 way switches.
Anything nasty here?
Patrick
Re: A127 mod
2003-04-09 by atuzzi
I did it:
I used switches with for 5 mm holes.
Without remove any knob or boards.
Just being careful using the drill starting with 1 mm and scaling til
the 5 mm.
the holes are done 10 mm from the right border and 12.5 mm from the
center of the driven filter.
I added a couple of photos under a127 mods
