Doepfer
Rear Panel Midi connector
2003-04-16 by Joe Buechler
Speaking of connectors in the back, if I were to install a DIN socket
in back of an A100 frame and wire the midi signal internally to the
A190 and A191, would simple wire work OK? Shielded two-conductor? Thin
coax?
Joe
Re: Rear Panel Midi connector
2003-04-16 by Tim Stinchcombe
Hi Joe,
socket
Thin
> coax?
The simple introductory book I have on MIDI says that screened twin
core cable of audio quality is fine. BUT, MIDI is not
straightforward. It works off a 'current loop', with opto-isolators
used to ensure that interconnected bits of kit are electrically
isolated from one another. The book strongly advises against trying
to drive two inputs from a single output (you wouldn't be able to
guarantee that either input would work properly) - this means that
you would still have to run your A-191 from the 'thru' of the A-190
(although conceivably you could connect them internally). Also the
point of using screened cable is to prevent interference
from 'escaping' from the lead, and not from noise penetrating it -
the screen on a lead is attached to both pin 2's at either end, but
the pin 2 on any socket is *not* connected to the chassis, in order
to maintain the isolation of all bits of kit.
I'm not sure how helpful the above is - you were obviously expecting
to connect things internally, only it might be less simple than you
had imagined (?).
Tim
Hi Timothy thanks for the information.
I have the A190's midi thru jack wired internally to the
A191's midi in jack with two short lengths of wire. That's been
working fine for a couple of years.
So now I'm thinking that if I connect a cable from a rear-panel DIN
socket to the terminals on the A190's midi in jack, whatever opti-iso
stuff is going on should be preserved. Do you think?
Joe
--- In Doepfer_a100@yahoogroups.com, "Tim Stinchcombe" <timothy@t...>
wrote:
> Hi Joe,
> socket
> Thin
> > coax?
> had imagined (?).
> Tim
iso
Yep. As long as you connect pin-for-pin (pins 4 and 5), like you have
obviously had to for the 190-191 connection, you should be OK.
Tim
Re: [Doepfer_a100] Re: Rear Panel Midi connector
2003-04-17 by Florian Anwander
Hi Tim
> ...The book strongly advises against trying
I was using paralleled MIDI-Outs for several MIDI-Ins for years. I had only
one combination of a certain Devices MIDI-In with the MIDI-Out of my SBX-80
did not work. I measured the resistor, that gives the current feed for the
loop, in the SBX and found, that it was out of the specification. After
replacing with the resistor with the correct value, also this worke again
fine.
Florian
