Doepfer
Re: Blown fuse again!
2003-06-02 by Tim Stinchcombe
Hi Roel,
> Today I bought 2 fuses of T100ma.
> As soon as I switched the case on,
> the fuse blew!!!
> To make sure it was not a bad fuse,
> I tried the spare one and...
> it acted the same way!!!
> I tell you also what happened to
> the 250ma fuse I tried.
> This kept working, but only the middle
> control leds of the bus in the case,
> was lighted. (I know 2 of them
> should light when everything's oké.
Is this with the case empty, i.e. no modules in it? If so, since it's
a new case, time to contact your local distributor! If you _have_ put
some modules in: are they all connected the right way round, i.e. the
red stripe on the ribbon at the bottom?; have any of the connectors
been forced on one pin too high or low?; are there any bent/damaged
pins on unused connectors shorting out?; are the modules known to
work in another case?
> Now, I know there's something
> else not right!
> This the second case this happends
> with!
What was the problem with the first one?
Many, many possibilities, but unless it is a clearly obvious physical
problem (like the above), my advice: call your distributor!
Tim
Blown fuse again!
2003-06-03 by Roel Steverink
Hi all,
the fuse blew!!!
else not right!
with!
Any others experienced problems
with new cases???
cheers,
Roel
