Doepfer
Re: Blown fuse again!
2003-06-02 by Tim Stinchcombe
Hi Roel,
> I hope that the cause. I noticed that on one of
> the connector's, the highest pins, where bent a
> little to the outside. I remember having trouble
> getting it connected! Now, this evening when I
> checked I saw that this connection was indeed
> not right and could explain the blown fuses.
If the top two pins were bent, then it sounds like the bus connector
was connected one pair of pins too low - this would then short the
-12V directly to ground, which fits with the symptoms you reported!
> Alas, the suggestions of Dieter you uploaded
> I can't use this evening anymore, cause I have
> no right fuses left. So tomorrow evening I will
> try it.
With some new fuses, and following Dieter's suggestions, hopefully
you will be up and running OK!
Tim
2003-06-03 by Roel Steverink
Date:  Mon Jun 2, 2003  9:03 pm
Subject:  Re: [Doepfer_a100] Re: Blown fuse again!
Hi Bakis,
try it.
No, the volts have been and are the right ones,
no doubt about that.
Roel
Bakis wrote:
>hi roel,
>so,it seems that the problem is in the case's bus
>board!as all the new modules have worked in your
>other(older) doepfer case,they seem to be ok!
>as far as i know from dieter,yes, a wrong connection
>to the bus board can lead to a blown fuse!
>but,also, check that your new "defective" doepfer case
>is set for 230 volts(europe)operation and NOT for 115
>volts!
bakis.
