Doepfer
Slightly off topic: ribbon cables
2003-06-13 by c45a6
Hello!
Does anyone know where I may buy ribbon cables, like those used by
Doepfer, to connect modules to the power supply?  I'm working on some
diy modules.
Or, perhaps a better question might be, if I wanted to make my own
ribbon cables, where do I buy the black connector thingies that clamp
on to the ribbon cable?  Some of my ribbon cables go between pcb
boards, so I need various widths and lengths.
Thanks a ton!
- Bret
Re: Slightly off topic: ribbon cables
2003-06-13 by Tim Stinchcombe
Hi Bret,
In the UK I use either Maplin or RapidElectronics - if you are not UK
based, check these out on the web so that you know what to look
for/ask for:
www.maplin.co.uk
Search on jb59 - these are the 10 way sockets that attach to the
cable. You'll also see fg44, 16-way sockets on same page.
Search on xr73 for the 16-way ribbon cable - they don't do 10 way, so
I just peel off 6 conductors (but they do sell it buy the foot, and
not a 30m reel!).
Search on jw62 for the double row PCB header plug - it's 36 pins
long, but again can be cut down.
www.rapidelectronics.co.uk
Open
http://www.rapidelectronics.co.uk/PDFs/CATPDFs/09_Connectors_multi.pdf
and search for 19-0300, the 10 way sockets (16 there too, 19-0305).
Search for 22-0560 for 10 way PCB header plug (which they don't do as
16 = 8+8, but you can still buy a 36+36!)
Open
http://www.rapidelectronics.co.uk/PDFs/CATPDFs/02_Cables.pdf
and search for 01-0172, 16 way ribbon cable: they do carry the 10 way
stuff (01-0167), but note it's sold on 30m reels only (but way
cheaper than Maplin for this amount)!
By the way, 'IDC' stands for something like 'insulation displacement
connector', i.e. is descriptive of what it actually is/does.
Hope that's of use.
Tim
--- In Doepfer_a100@yahoogroups.com, "c45a6" <clone45@h...> wrote:
> Hello!
some
> diy modules.
clamp
> Thanks a ton!
> - Bret
Re: [Doepfer_a100] Slightly off topic: ribbon cables
2003-06-13 by Paul Schulz
Hi Bret,
just look for a store which sells electronic components like resistors,
LEDs etc. Normally they should have as well the ribbon cables as the
connectors.
Check out Conrad ( www.conrad.com ) As far as i know they have a
internet store.
cheers,
c45a6 wrote:
> Hello!
> diy modules.
> Thanks a ton!
> - Bret
> Yahoo! Groups Sponsor
> <http://rd.yahoo.com/M=251812.3170658.4537139.1261774/D=egroupweb/S=1705032144:HM/A=1564415/R=0/SIG=11t6t7kdo/*http://www.netflix.com/Default?mqso=60164784&partid=3170658>
> To unsubscribe from this group, send an email to:
> doepfer_a100-unsubscribe@yahoogroups.com
> Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service
> <http://docs.yahoo.com/info/terms/>.
