Doepfer
ouputs?
ouputs?
2003-07-26 by mdimmm@hotmail.com
hello,
could someone let me know if the doepfer a-100 uses the +4 dBu or -10 dBV
"line" standard for its outputs?
none of the outputs are balanced, right? (also the A-181, although it has a
TRS "stereo" connector instead of a TS "mono" connector?)
would it make any difference to use balanced "stereo" cables instead of
unbalanced "mono" cables when connecting the a-100 to a mixer with balanced
line inputs?
thanks!
mdimm
Re: ouputs?
2003-07-27 by ps_minor
a balanced or unbalanced cable shouldn't make any difference when
connecting the unbalanced a100 to a balanced mixer input.  it'll always be
unbalanced.
not sure about the output db specs but i connect my a181 to mixer line-inputs
via unbalanced cables and get good results, plenty of level.  however, when
recording i always connect the unbalanced output of the a100 to a
transformer balanced direct box, then connect the DI's balanced mic level
output to a balanced mic input on the mixer or outboard mic pre.   seems to
have slightly better headroom and lower noise that way.  biggest benefit of
using a good DI though is improvement in detail and tone, especially w the
low end.
-psm
--- In Doepfer_a100@yahoogroups.com, "mdimmm@h..." <mdimmm@h...>
wrote:
> hello,
dBV
balanced
> line inputs?
> thanks!
> mdimm
