Fwd: AW: [Doepfer_a100] The case is back! doepfer's answer.
2003-09-04 by Bakis Sirros
--- Dieter Doepfer <hardware@doepfer.de> wrote: > From: "Dieter Doepfer" <hardware@doepfer.de> > To: "Bakis Sirros" <synth_freak_2000@yahoo.com> > Subject: AW: [Doepfer_a100] The case is back! > Date: Thu, 4 Sep 2003 17:21:00 +0200 > > please forward......... > > > I placed my A190 in the third case (which is still > > being filled) in the right upper corner. When > > I had connected it and tried, I was suprised that > > it didn't work! I thought how's that possible? > > Then all of a sudden it came to me, damn this > module > > needs an additional 5v!!! > > You understand, I don't want to put it in the > first > > case again, this is right place for it! > > I fear I can't remove the 5v power from the first > case > > and put it in the third?! > > You simply have to move the +5V adapter to the bus > board of the A-190 (I > assume you have the 5V adapter, not the "full" 5V > supply). > > > Another, this time strange thing is followed. I > have > > my 7th oscillator in the third case. No, comes the > strange > > thing. It works, but not as it should be. I only > get > > very high frequenties. I can't even go through the > whole > > range up, cause when it reaches 3+ the sound > totally dissapears! > > However the sound becomes a little bit stronger > when I go to -2. > > But when I plug it into the A-176 the sound is > normal again??? > > I don't understand why this is possible. > > Maybe there is a problem with the power consumption. > 7 A-110 consume 7x70mA > = 490 mA. I assume there are some more modules in > the frame and maybe the > total current is more than 650mA. > > > Important to say is, that I first wrongly connect > it too > > the busboard! I plugged it and missed two din > pins. > > Is it possible that this short mis-connection has > caused > > this??? Isn't the module protected against this? > > Wrong bus connection may destroy modules under > certain conditions ! The > A-100 user's guide reads (chapter 2.2 / installing > modules, page 4 and > following pages): "... Failure to check this may > result in the module�s > instant destruction as soon as the power is turned > back on.". > > Best wishes > Dieter Doepfer > > > ===== Bakis Sirros Parallel Worlds / Polariton Athens-Greece [Doepfer_a100] group owner http://www.rubber.gr http://www.ward12.com __________________________________ Do you Yahoo!? Yahoo! SiteBuilder - Free, easy-to-use web site design software http://sitebuilder.yahoo.com
