Doepfer
What is total current draw of A-190 MCV?
2003-09-21 by shm1400
According to Doepfer, the A190 midi to CV interface requires 10ma,
but also requires a 5v source with 50ma.  So, when I use the low
cost 5v adapter, does this mean it is drawing a total of 60ma?  Or
is there a different way to add this up?
Thanks in advance to anybody who can let me know.
Re: [Doepfer_a100] What is total current draw of A-190 MCV?
2003-09-22 by Bakis Sirros
hello shm1400,
the a190 requires 50mA from the +5volts adapter(that
leaves another 50mA of +5volts that the low cost
adapter can handle)and 10mA from the +12/-12 volts
supply.that means that the a190 requires a total of
60mA from the main PSU.this is because the +5volts low
cost adapter,is an adapter,not a power supply.it takes
it's +5volts current from the main PSU(from the
+12volts line of the PSU).so,the a190 draws 60mA,in
total,from the main PSU.
bakis.
> requires 10ma,
> use the low
> total of 60ma?  Or
Bakis Sirros
Parallel Worlds / Polariton
Athens-Greece
[Doepfer_a100] group owner
http://www.rubber.gr
http://www.ward12.com
Do you Yahoo!?
Yahoo! SiteBuilder - Free, easy-to-use web site design software
http://sitebuilder.yahoo.com
