Fwd: AW: [Doepfer_a100] Re: more news about the a154(answers from doepfer).
2004-01-16 by Bakis Sirros
--- Dieter Doepfer <hardware@doepfer.de> wrote: > From: "Dieter Doepfer" <hardware@doepfer.de> > To: "Bakis Sirros" <synth_freak_2000@yahoo.com> > Subject: AW: [Doepfer_a100] Re: more news about the > a154 and other modules from doepfer. > Date: Fri, 16 Jan 2004 16:17:12 +0100 > > Please forward ... > > > --- In Doepfer_a100@yahoogroups.com, Bakis Sirros > > <synth_freak_2000@y...> wrote: > > > dieter says:> > > > Christian is also about to put the finishing > touches > > > to the A-154 and he/we are not sure in some > details. > > > If it comes to the details it is not so easy to > decide > > > how the module should work. E.g. which pendulum > type > > > he should offer ? Should the first/last step > played > > > twice or only once (MAQ users will know the > > > difference). In the first case the rhythmical > > > structure remains the same by changing the > running > > > mode but the first resp. last step is played > twice. In > > > the second pendulum mode the first/last step is > only > > > played once. > > > > I think it should both, perhaps you could use a > switched pot at the > > Mode Manual pot. Position in is played once, > position pulled out is > > played twice. > > > > > And: should the CV addressed mode be triggered > by the > > > clock or be completely independent of the clock > ? > > > > I think both are very useful, a switched pot at > the Clock Manual > > position would take care of this. > > Of course all this would be possible but require > another redesign of the > module. > After the last redesign all port pins are used up. > There is no pin left to > add switches. > So another microcontroller with more port pins would > have to be used. > So far we do not used switched pots and our > manufacturer does not offer > switched pots. > I think the suggested modifications would delay the > module by several > months. > I think we should come to an end not to get the same > procedure as for the > TKB. > > We discussed another solution for the two pendulum > types: We could introduce > another mode (pendulum 2). But as there is no free > LED we would have to use > a second LED to display the pendulum 2 mode. Same is > valid for 2 different > CV addressed modes. > But I'm not sure if this is necessary as the > differences are not very > significant and it is more important to have a > module that is simply > operated (not as the A-190, I hate the operation of > the A-190 - but we were > young and needed the money in 1996 .... :-) > > Best wishes > Dieter Doepfer > > > ===== Bakis Siros Parallel Worlds / Polariton Athens-Greece [Doepfer_a100] group owner http://www.rubber.gr http://www.ward12.com __________________________________ Do you Yahoo!? Yahoo! Hotjobs: Enter the "Signing Bonus" Sweepstakes http://hotjobs.sweepstakes.yahoo.com/signingbonus
