Fwd: AW: [Doepfer_a100] news about the a149-1 and wine tasting competition from doepfer.
2004-01-16 by Bakis Sirros
--- Dieter Doepfer <hardware@doepfer.de> wrote: > From: "Dieter Doepfer" <hardware@doepfer.de> > To: "Bakis Sirros" <synth_freak_2000@yahoo.com> > Subject: AW: [Doepfer_a100] Re: more news about the > a154 and other modules from doepfer. > Date: Fri, 16 Jan 2004 16:17:12 +0100 > > Please forward ... > > > -----Urspr�ngliche Nachricht----- > > Von: Tommy DOG [mailto:mrsvomit@tommydog.com] > > Gesendet: Donnerstag, 15. Januar 2004 20:57 > > An: Doepfer_a100@yahoogroups.com > > Betreff: [Doepfer_a100] Re: more news about the > a154 and other modules > > from doepfer. > > > > > > --- In Doepfer_a100@yahoogroups.com, Bakis Sirros > > <synth_freak_2000@y...> wrote: > > > dieter says: > > > > > <Snip> > > >" to emulate the > > > behaviour of the original Buchla module it is > true > > > that 2 separate shift registers are the right > solution. > > > > This Isn't clear whether this was an oversight in > design or a > > mistake that should be corrected. > > It depends upon the point of view. You could call it > another feature or a > mistake whatever you want. We knew that the Buchla > uses two shift registers > but we were of the opinion that it is not necessary. > So we did not oversee > that but believed that the version with one shift > register is an equivalent > solution. It was no problem to introduce a second > shift register and so we > did it (even though we think that it is not > necessary, simply two different > types of random sequences appear but one could not > say that one is better > than the other, that's the basic of random - or > better pseudo-random as the > Buchla approach - like any approch with feedback > shift registers - is only > pseudo-random in contrast to "real" random like the > A-118 or other > semiconductor noise based designs). > > To have a 100% copy of the Buchla module 2 shift > registers are required. But > to have only one shift register that is triggered > from both clock sources > creates also random voltages but a little bit > different as each register is > triggered by its own clock. From our point of view > the version with one > register is "more random" as both clock sources > cause an advance to the next > state. > > > Is this a adjustment that users can make? > > The shift registers are made with a PIC > (microcontroller). So it depends > upon the PIC in the module which version is > included. We could try to start > a competition (like wine tasting): test two A-149-1 > and find out which is > the version with one and which the version with 2 > shift registers (of course > with the corrected rising edge trigger) :-) > > Best wishes > Dieter Doepfer > > ===== Bakis Siros Parallel Worlds / Polariton Athens-Greece [Doepfer_a100] group owner http://www.rubber.gr http://www.ward12.com __________________________________ Do you Yahoo!? Yahoo! Hotjobs: Enter the "Signing Bonus" Sweepstakes http://hotjobs.sweepstakes.yahoo.com/signingbonus
