Patchable??
2005-02-26 by boward_k
What other modular systems/analogue synthezisers could you patch up with a-100?
2005-02-28 by Bakis Sirros
hello, with almost everything i guess? other modular/analogue systems i have used and work fine are: AS integrator, analogue solutions concussor, technosaurus selector, roland system 100, korg ms-series, korg monopoly, arp 2600, oberheim SEM, 4- voice, sh101, sh2, korg trident, and possibly ems vcs3. that means with any other analogue gear, as long as this gear doesn't output more than 15 volts(am i right dieter?) also, you'll have to use attenuators patched in between a100 and some other analogue gear, in order to match the various voltage ranges for best results. bakis. --- boward_k <bovar.kalim@eudoramail.com> wrote: > > What other modular systems/analogue synthezisers > could you patch up > with a-100? > > > > ===== Bakis Siros Parallel Worlds / Polariton Athens-Greece [Doepfer_a100] group owner http://www.shimarecords.co.uk http://www.ward12.com __________________________________ Do you Yahoo!? Take Yahoo! Mail with you! Get it on your mobile phone. http://mobile.yahoo.com/maildemo
2005-02-28 by Tommy DOG
--- In Doepfer_a100@yahoogroups.com, Bakis Sirros <synth_freak_2000@y...> wrote: > hello, > with almost everything i guess? > other modular/analogue systems i have used and work > fine are: > AS integrator, analogue solutions concussor, > technosaurus selector, roland system 100, korg > ms-series, korg monopoly, arp 2600, oberheim SEM, 4- > voice, sh101, sh2, korg trident, and possibly ems > vcs3. I'd add that I think a few people here use the Moog MoogerFooger series. -Some please verify this. TD
2005-02-28 by selfoscillate
--- In Doepfer_a100@yahoogroups.com, "Tommy DOG" <mrsvomit@t...> wrote: > > --- In Doepfer_a100@yahoogroups.com, Bakis Sirros <synth_freak_2000@y...> wrote: > > hello, > > with almost everything i guess? > > other modular/analogue systems i have used and work > > fine are: > > AS integrator, analogue solutions concussor, > > technosaurus selector, roland system 100, korg > > ms-series, korg monopoly, arp 2600, oberheim SEM, 4- > > voice, sh101, sh2, korg trident, and possibly ems > > vcs3. > > I'd add that I think a few people here use the Moog MoogerFooger series. > -Some please verify this. > > TD of course all the moog stuff is working together with the a100. virtually any analogue modular works with the a100. some need extra care, if they don't follow the 1v/oct standard, and some have a different voltage range for the cv's, but basically they all work together. best wishes ingo
2005-02-28 by Glenn Gregory
I am currently using my Doepfer with a 22 space synthesizers.com system, a Korg MS setup (primarily MS-50 and SQ-10, but sometimes the MS-10 or 20 squeeze in there) and some Blacet and Paia modules. The short answer is everything works together pretty well. The levels on the .com stuff are much higher than on the Doepfer, so I have to play around with attenuators sometimes. Also, obviously, the Doepfer, Blacet and Paia use mini-jack whereas the .com uses 1/4" jacks (as do MOTM). It's not a big deal at all - I have a .com mini->1/4" interface module that I plug in and out of. Plus I have a whole lot of mini->1/4" converter plugs (the kind you put on the end of your headphones). The Korg MS stuff can be a bit more of a challenge. The MS-50 accepts both hertz/volt and volt/octave inputs for the OSC, but the envelopes use inverted gates. If I need to use the MS envelopes or use the gates from the SQ-10, I run the gates through the .com Q125 module to invert and offset them by 5V. (This can also be accomplished with the inverter and voltage source on the MS-50, but it requires more patching.) I'm actually a big fan of this mix-and-match aproach for a number of reasons. I'm really enjoying the moog-iness of the .com stuff right now, but I don't have a full system yet, so I can supplement it with Doepfer stuff. Also, Doepfer has a lot of unique modules that I'll want to keep using, no matter how big my .com stuff gets. But most significantly, I find the sound changes quite a bit with different inter-system patching. E.g. the .com and the Doepfer trans ladder filter sounds very different with an MS-50 OSC patched into it than with a Doepfer OSC. selfoscillate <synaptic_music@yahoo.com> wrote: --- In Doepfer_a100@yahoogroups.com, "Tommy DOG" <mrsvomit@t...> wrote: > > --- In Doepfer_a100@yahoogroups.com, Bakis Sirros <synth_freak_2000@y...> wrote: > > hello, > > with almost everything i guess? > > other modular/analogue systems i have used and work > > fine are: > > AS integrator, analogue solutions concussor, > > technosaurus selector, roland system 100, korg > > ms-series, korg monopoly, arp 2600, oberheim SEM, 4- > > voice, sh101, sh2, korg trident, and possibly ems > > vcs3. > > I'd add that I think a few people here use the Moog MoogerFooger series. > -Some please verify this. > > TD of course all the moog stuff is working together with the a100. virtually any analogue modular works with the a100. some need extra care, if they don't follow the 1v/oct standard, and some have a different voltage range for the cv's, but basically they all work together. best wishes ingo Yahoo! Groups SponsorADVERTISEMENT --------------------------------- Yahoo! Groups Links To visit your group on the web, go to: http://groups.yahoo.com/group/Doepfer_a100/ To unsubscribe from this group, send an email to: Doepfer_a100-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. --------------------------------- Do you Yahoo!? Yahoo! Mail - You care about security. So do we. [Non-text portions of this message have been removed]
