Alternatice to G6
2005-03-05 by Antonio Grazioli
If you want an alternative to the "high-priced" G6s I think that you might consider DIY. It' not that difficult to build a custom frame for Doepfer modules. If you are in Europe you might consider RS Components (I think they are located in UK but sell worldwide) Go to: www.rs-components.com <http://www.rs-components.com/> I used: Part 437-2551 for the frame. A 6 Units Frame (it's a Schroff) It's about 80 euros (60 UKP) , doesn't have top/Bottom and rear covers, but there is another option on their site (costs more, though) . Doepfer screws won't fit on this rails, but 300 2,5mm screws costed me 5 euros. Part 434-201 to make the bus. About 20 Euros (15 UKP) A single strip is large enough to be cut in two or three lines (or four, like I did) to make a custom bus Connectors for the bus are really cheap, you can buy different kinds of them.only a few euros The most expensive part is the PSU.I used Computer PSU at the moment. I know they are not the best, but as a temporary solution they work very well. also used a 7805 regulator to get the +5V. Connecting and Soldering the PSU is quite simple, you don't need to be an electronic engineer, just need to know the difference between +12, -12 and +5Volts.However, if you are not experienced at all ask a friend to do it for you. This is the most delicate part, if you do something wrong you are probably gonna burn some precious modules.(see my A-190---grr...;-)) With just about 100 euros you can build an alternate G6 frame. Dieter is kind enough to post plenty of information on his site about voltages, connections and so on. I Had a G6, sold it and with the same money bought about 3 frames (2 and a half, to be honest) see the results here: www.autodafe.net/doepfer/cabinet2.htm [Non-text portions of this message have been removed]
