Doepfer
A-155 16-step sequence modification
2005-03-14 by Tim Stinchcombe
Hi list,
Having looked at Paul's excellent idea for a permanent 'adapter' to
allow a 16-step sequence to replace the 2 external modules (shown in
Fig 6 in the manual), it turned out to be so simple I immediately put
soldering iron to stripboard and made such a thing up.
It is certainly not a trivial mod, but only requires a single IC, 2
sockets, 2 LEDs, and 2 resistors. I've produced a simple schematic
and taken a few pictures of what I've done, and if people are
interested I could post these to the photos section, along with some
(rough) 'instructions'. Let me know!
Tim
Re: [Doepfer_a100] A-155 16-step sequence modification
2005-03-14 by Brandon Daniel
Tim Stinchcombe said:
> Hi list,
Definitely something you should share with the group! I'd bet Analogue
Haven would want to put it in the DIY section of the website as well...
-Brandon
 _______________________________________
|| Eat your greens, especially broccoli |
|| And always say "thank you" |||||||||||
|| Especially for broccoli ||||||||||||||
Re: A-155 16-step sequence modification
OK, so here is my (relatively) straightforward mod to the A-155 to
allow for permanent Trig and CV outputs to turn it into a simple 16-
step sequencer, thus removing the need for external modules A-160 and
A-150, as shown in Fig 6 in the manual. I deliberately don't want to
be too 'prescriptive', as what *I* have done is quite a lot more than
really needs to be (for several reasons: I move my modules around a
lot, so a separate 4hp plate with 10-way IDC + ribbon fits the bill;
I was too lazy to consider pulling various boards off the 155 to
drill extra holes etc.). I used a piece of stripboard because I had
some, and I more-or-less just added the wires as I needed to, cutting
tracks where needed - the mod could be done by sticking the IC on its
back and soldering directly onto its legs.
The gif file shows the schematic: the chip is a CD4053 or something
equivalent, such as an HEF/HCF4053 etc. Resistors could be 2k2 for
use with 5mA LEDs (I used 5k1 as the LEDs I had were low-current 2mA
types, left over from some kit I built).
The pictures:
155_16_step_gen - a general view of the back, showing the ribbon
cable I used. Note that the blue wire is a factory-fitted mod, and
not part of this one!
155_16_step_mod - my new panel on the right of the 155: the top
socket is the combined trigger rows, the bottom one is the CV; the
LEDs are in line with the pots on the row that is active.
155_16_step_outs - location of the row 'post outs', these are the
legs of 100ohm resistors, which can be traced directly to the 'post
out' sockets.
155_16_step_strip - shows how little there is, most of the
complication arises because of my use of the 10-way IDC header. It
should be easy enough to wire point-to-point straight from the
schematic.
155_16_step_trig_etc - shows the other outputs:
+12V taken from the top pair of pins on the back of the power
connector on the 'controller board'
GND taken from any of the middle 3 pairs (I used the pair second from
bottom).
Pin 6 on the '4024 is just that. There is no other connection to this
pin on the board (the 4024 is right next to the other connector).
Trig 1 is the second pin _down_ on the back of the connector on
the 'trigger/gate adapter board'
Trig 3 is the second pin _up_ on this connector (you can easily trace
tracks to the sockets to be sure)
There's no need for any sort of switch: when not in use there are no
loading effects on the normal 8-step circuitry - when you want to go
16-step, just plug in!
The only thing I haven't catered for is if _negative_ voltages are
input to the bottom row external inputs. Since I have taken Vee, pin
7 to ground, the 4053 will not be happy with such voltages (it's
highly unlikely I will ever want to do this). If bothered about this,
there are two 79L05s (one on each potentiometer board), and the -5V
from either could be taken to pin 7 (the 4053s already in the 155 are
wired that way).
That's about all I can think of (its enough to be going on with!).
Tim
Modifications Re: A-155 16-step sequence modification
2005-03-14 by synthtrader
hello,
<< Definitely something you should share with the group! I'd bet
Analogue Haven would want to put it in the DIY section of the
website as well... >>
Thanks Brandon. You're right, I would.
Tim - is it OK?
I have a lot of stuff to add to the site but it won't happen until
our new site is up over the next week or so. But here are some sneak
previews...
Synthi A in Doepfer format:
http://www.abiotic.net/schism/allanhall/synthi/VCS3%20Panel.jpg
Colin Fraser P3 in Doepfer format:
http://www.abiotic.net/schism/allanhall/p3/
A-127 modified with BPF/LPF switches per filter:
http://www.abiotic.net/schism/allanhall/a127/
Note that these are DIY and not commercial products. They are not
for sale. These 3 great designs/mods are made by Allan Hall. I have
some others to upload from other people. Details on my site when I
find time.
Thank you,
Shawn Cleary
www.analoguehaven.com
