Doepfer
tools for synchro start
2005-09-26 by Florian Anwander
I am looking for something, that assumingly does not exist. ;-/ Let me
describe it:
We are several guys making improvised music with different type of
sequencers, drummachines, arpeggiators. We do realy create the patterns
  live, so we cannot start all the seq/drum/arpggs at the same time
(most of the gear does not allow pattern creation in play mode).
Some of the gear is 40 years old, some is latest laptop stuff. So there
is MIDI-Clock, Din-Sync and simple 16th trigger with separate start/stop
controle.
What I am looking for is a set of hardware tools:
- The first tool should read the clock and start/stop signals from a
master (or create the clock on its own). From this masterclock it should
create a kind of "flag" trigger at the first beat of each bar (or every
second/fourth/eight... bar). It should send the clock, the standard
start/stop signal and the additional flag trigger.
- the second tool should read the clock and this flag trigger at its
input. It should have also a button "local start". When I hit the button
"local start" the tool should send a start signal (and of course the
clock itself) to its output.
- the third part should convert all this to different types of clocks
and star stop signals.
I could imagine, that the tools #1 and #2 use MIDI-Clock and tool #3
could be a standard MIDI-converter.
Does anyone know about some gear that is able to do this? Or did anyone
ever try something like this?
I could realize this with diy'ing for DIN-Sync and analog trigger, but I
am out of the business when it affects MIDI.
regards, Florian
RE: [Doepfer_a100] tools for synchro start
2005-09-26 by n keller
Florian,
I'm not sure if this helps and it doesn't cover all your needs.....
I sometimes use my swedish drum machine (now with sampling! :} )  as a
clock/trigger source.  There are 6 outputs, and I can use voices which are
set up as Impulses for triggers.   A 16th note pattern could be my clock at
one output and I could have a start of measure trigger on another output.
Changing the preset "beat" pattern would be like changing to different clock
divisions and trigger patterns, as long as you set up some presets of
course.  Then with muting tracks live (your local start) and even using the
song editor you can do a bunch ahead of time and on the fly.  Of course, you
can also edit the pattern live, chain patterns together..... and add
SHUFFLE/SWING.......awesome.  Sometimes I use a shuffled trigger pattern
from the drum machine and a CV pattern from the MAQ 16/3 to make shuffled
synth loops.
So anyway,  if you have one of these you've probably thought of this.  If
you don't have one, borrow one and try it out.  so many possibilities.    I
asked the swedes to release a dedicated sequencer based on their drum
machine (and now synth) but they didn't see the point.  Shame.
Good luck.
nick
>From: Florian Anwander <Florian.Anwander@consol.de>
>Reply-To: Doepfer_a100@yahoogroups.com
>To: A100 <Doepfer_a100@yahoogroups.com>
>Subject: [Doepfer_a100] tools for synchro start
>Date: Mon, 26 Sep 2005 19:02:13 +0200
>Hi,
>describe it:
>controle.
>regards, Florian
On the road to retirement? Check out MSN Life Events for advice on how to
get there! http://lifeevents.msn.com/category.aspx?cid=Retirement
2005-09-26 by ALX002
Hey Florian
I'm searching the same Magical BOX......
I have this link:
http://home.netspeed.com.au/aistorm/sync2.html
But this box has a High cost and has just a midi out
Port. I would like this same box but with 3  START
BUTTON SYNC and with Midi beat clock out + DYN SYNC
OUT + CLOCK CV OUT to be compatible with all analog
gears.
I'm ready to buy a box like that for 230 EUROS
ALEX
--- n keller <nirokesan@hotmail.com> a écrit :
Florian,
your needs.....
sampling! :} )  as a
on another output.
some presets of
synth loops.
thought of this.  If
based on their drum
 Shame.
Good luck.
nick
>Hi,
exist. ;-/ Let me
>describe it:
different type of
create the patterns
at the same time
play mode).
separate start/stop
>controle.
signals from a
each bar (or every
clock, the standard
trigger at its
(and of course the
types of clocks
this? Or did anyone
>regards, Florian
get there!
      SPONSORED LINKS
                                                A100
                                 Modular system
                            Synthesizer
Electronic payment
Electronic test equipment
      Guitar synthesizer
  YAHOO! GROUPS LINKS
    Visit your group "Doepfer_a100" on the web.
 Doepfer_a100-unsubscribe@yahoogroups.com
    Your use of Yahoo! Groups is subject to the Yahoo!
Terms of Service.
___________________________________________________________________________
Appel audio GRATUIT partout dans le monde avec le nouveau Yahoo! Messenger
Téléchargez cette version sur http://fr.messenger.yahoo.com
Re: [Doepfer_a100] tools for synchro start
2005-09-27 by Florian Anwander
Hi Alex
> I have this link:
This is really already close to what I am looking for. I'd only need
converters for MIDI-to-DINSync and DIN-Sync-to-analog-Clock.
> Port.
I didn't find any pricing.
Florian
AW: [Doepfer_a100] tools for synchro start
2005-09-27 by Dieter Doepfer
Look at the MSY2....
Dieter Doepfer
> [mailto:Doepfer_a100@yahoogroups.com]Im Auftrag von Florian Anwander
> Gesendet: Dienstag, 27. September 2005 09:26
> Betreff: Re: [Doepfer_a100] tools for synchro start
> Hi Alex
> > I have this link:
> > Port.
> Florian
