RE: [Doepfer_a100] Re: Doepfer MAQ quantisation question
2005-09-30 by David Salter
Dieter, That would certainly be useful. thank you. Rgds David David Salter Senior Project Manager Reuters Ltd Tel +44 20 7542 2402 Mob +44 7990562402 email david.salter@reuters.com RM david.salter.reuters@reuters.net ________________________________
From: Doepfer_a100@yahoogroups.com [mailto:Doepfer_a100@yahoogroups.com] On Behalf Of Dieter Doepfer
Sent: 30 September 2005 11:36
Subject: AW: [Doepfer_a100] Re: Doepfer MAQ quantisation question
I don't think that this will be possible as the position of each
potentiometer is measured only when the step in question is called up. And
there is another problem: there is no LC display but only a 3 digit LED
number display that is able to display only numbers or characters that can
be realized with the 7 segments ("#" e.g. would be not possible).
But it should be possible to display the notes (2.g. "C2")in the single step
mode by replacing the "#" by another character that can be made with the
segments of the display.
Best wishes
Dieter Doepfer
> [mailto:Doepfer_a100@yahoogroups.com]Im Auftrag von analog1k
> Gesendet: Donnerstag, 29. September 2005 21:48
> Betreff: [Doepfer_a100] Re: Doepfer MAQ quantisation question
> Dieter could it be possible to write some new software
> for the MAQ, ie: when you turn any of the potentiometers
> (knobs) on the 3x16 rows, in the small LCD screen it would
> tell you what note it is on (see - the P3 sequencer) ie:
> C2, G#3, C4 etc, rather than just tuning the pitch.
> Just an idea, but more of a request actually, after all
> you do listen to ideas - am I right ? :)
> A1k
> --- In Doepfer_a100@yahoogroups.com, "Dieter Doepfer" <hardware@d...>
> wrote:
> > No. Even the CV outputs of the MAQ16/3 are quantized in 1/12V steps
> (in all
> > note modes) !
> > Only for the very first MAQ16/3 before about 1996/1997 (those without
> > CV/Gate outputs from the factory and software 2.xx or earlier) a guy
> here in
> > Germany offered a non-quantized CV out modification (he simply
> buffered the
> > 4051 multiplexer outputs with an OpAmp). But the "original" MAQ16/3 CV
> > outputs from the factory are quantized !
> > Best wishes
> > Dieter Doepfer
> >> snip <<
YAHOO! GROUPS LINKS
* Visit your group "Doepfer_a100 <http://groups.yahoo.com/group/Doepfer_a100> " on the web.
* To unsubscribe from this group, send an email to:
Doepfer_a100-unsubscribe@yahoogroups.com <mailto:Doepfer_a100-unsubscribe@yahoogroups.com?subject=Unsubscribe>
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service <http://docs.yahoo.com/info/terms/> .
Visit our Internet site at http://www.reuters.com
To find out more about Reuters Products and Services visit http://www.reuters.com/productinfo
Any views expressed in this message are those of the individual
sender, except where the sender specifically states them to be
the views of Reuters Ltd.
