Doepfer
doepfer modules in Analogue Solutions AS1600 case.
2006-01-05 by danfarmer19732003
I bought a doepfer module recently and I was wondering if I could
install that into a AS1600 case from analogue solutions.
I heard that the doepfer modules power adapter must be fit upside down
into the AS case board ( is this true? ), or is it that the doepfer
modules fit upside down in the doepfer case and right side up in an AS
case.
Thanks for you help.
Re: doepfer modules in Analogue Solutions AS1600 case.
2006-01-06 by selfoscillate
hello,
you just have to make sure that the red stripe of the
power cable is connected to the -12 volt pin of
the buss board. in doepfer cases the red stripe is
orientated downwards, while in other cases it may
be the other way around.
best wishes
ingo
--- In Doepfer_a100@yahoogroups.com, "danfarmer19732003"
> case.
