has anybody tried Stika foil cutter
2005-08-28 by mikezcnc
and Cutronics copper foil? A company in England claims good results although not as cheap as TT. Mike
2005-08-29 by Steve
--- In Homebrew_PCBs@yahoogroups.com, "mikezcnc" <eemikez@c...> wrote: > and Cutronics copper foil? A company in England claims good results > although not as cheap as TT. Mike Interesting. So the idea is to cut the copper and apply to a bare fiberglass board? I've used a vinyl sign cutter and used the vinyl as the resist. See samples in the Files section. However, small traces are very difficult to weed. It may or may not be easier with copper. When you cut the vinyl, the adhesive flows together behind the blade. Then when weeding, the vinyl tends to lift thin pieces and stretch them out or snap them. Copper being stiffer, it may not be as much of an issue but imagine having to weed all the holes on a board with a few 28 and 40 pin ICs. Steve Greenfield
2005-08-29 by Steve
--- In Homebrew_PCBs@yahoogroups.com, "mikezcnc" <eemikez@c...> wrote: > and Cutronics copper foil? A company in England claims good results > although not as cheap as TT. Mike BTW, from what I've read in various sign forums, the Stika cutters are considered kind of low end cutters. No reason you can't use another cutter, anything that is rated to be able to cut sandblast mask should handle Cutronics copper foil. I made a couple of PCBs using cut vinyl as resist, using an old Graphtec vinyl sign cutter. On the one that is undrilled, I used sort of a surface mount construction using standard parts with leads clipped short. <http://groups.yahoo.com/group/Homebrew_PCBs/files/Sign_Cutter_to_make_PCBs/> I think results could be very useable with the right brand/type of vinyl and with CNC predrilled holes. It's very quick to do, on this cutter I can do up to about 18 inches wide so that's a lot of boards. Even on my old, slow cutter it's done pretty quickly and as you can see there is very little undercutting. However, the adhesive on the vinyl I used was a little stringy and caused some slightly rough edges. There are brands of vinyl specifically made so the adhesive does not reseal behind the cutter. Steve Greenfield
2005-08-29 by Steve
--- In Homebrew_PCBs@yahoogroups.com, "mikezcnc" <eemikez@c...> wrote: > and Cutronics copper foil? A company in England claims good results > although not as cheap as TT. Mike Not too bad. http://www.techsoftuk.co.uk/ 130 pounds for a roll 55m long and 200mm wide, or 10 sheets 300x200mm for 10 pounds. Shipping could be a bit. Steve Greenfield
2005-08-29 by Bob_xyz
From their site, it seems that the cutting machines themselves are only available for sale to educational institutions and, beyond that, only to ones that are located in the UK. Regards, Bob --- In Homebrew_PCBs@yahoogroups.com, "Steve" <alienrelics@y...> wrote: > --- In Homebrew_PCBs@yahoogroups.com, "mikezcnc" <eemikez@c...> wrote: > > and Cutronics copper foil? A company in England claims good results > > although not as cheap as TT. Mike > > Not too bad. > > http://www.techsoftuk.co.uk/ > > 130 pounds for a roll 55m long and 200mm wide, or 10 sheets 300x200mm
> for 10 pounds. Shipping could be a bit. > > Steve Greenfield
2005-08-30 by mikezcnc
Thank you Steve! Mike --- In Homebrew_PCBs@yahoogroups.com, "Steve" <alienrelics@y...> wrote: > --- In Homebrew_PCBs@yahoogroups.com, "mikezcnc" <eemikez@c...> wrote: > > and Cutronics copper foil? A company in England claims good results > > although not as cheap as TT. Mike > > BTW, from what I've read in various sign forums, the Stika cutters are > considered kind of low end cutters. > > No reason you can't use another cutter, anything that is rated to be > able to cut sandblast mask should handle Cutronics copper foil. > > I made a couple of PCBs using cut vinyl as resist, using an old > Graphtec vinyl sign cutter. On the one that is undrilled, I used sort > of a surface mount construction using standard parts with leads > clipped short. > <http://groups.yahoo.com/group/Homebrew_PCBs/files/Sign_Cutter_to_mak e_PCBs/> > > I think results could be very useable with the right brand/type of > vinyl and with CNC predrilled holes. It's very quick to do, on this > cutter I can do up to about 18 inches wide so that's a lot of boards. > Even on my old, slow cutter it's done pretty quickly and as you can > see there is very little undercutting. However, the adhesive on the > vinyl I used was a little stringy and caused some slightly rough edges. > > There are brands of vinyl specifically made so the adhesive does not
> reseal behind the cutter. > > Steve Greenfield
2005-09-05 by Steve
Those look like they are just regular vinyl sign cutters. Check out the Links on the signmaker list: http://groups.yahoo.com/group/signmaker Steve Greenfield --- In Homebrew_PCBs@yahoogroups.com, "Bob_xyz" <bob_barr@h...> wrote:
> From their site, it seems that the cutting machines themselves are > only available for sale to educational institutions and, beyond that, > only to ones that are located in the UK. > > > Regards, Bob > > > --- In Homebrew_PCBs@yahoogroups.com, "Steve" <alienrelics@y...> > wrote: > > --- In Homebrew_PCBs@yahoogroups.com, "mikezcnc" <eemikez@c...> > wrote: > > > and Cutronics copper foil? A company in England claims good > results > > > although not as cheap as TT. Mike > > > > Not too bad. > > > > http://www.techsoftuk.co.uk/ > > > > 130 pounds for a roll 55m long and 200mm wide, or 10 sheets > 300x200mm > > for 10 pounds. Shipping could be a bit. > > > > Steve Greenfield
