Silk Screen Printing overlays
2005-09-22 by Andrew Mawson
Has anyone got a homebrew set up working for printing component location overlays? Any tips and gotcha's ? Been toying with the idea of making a small screen printing set up but no point in re-inventing the wheel if you've been there before! AWEM
2005-09-22 by Stefan Trethan
On Fri, 23 Sep 2005 00:08:58 +0200, Andrew Mawson <andrew@...> wrote: > Has anyone got a homebrew set up working for printing component > location overlays? Any tips and gotcha's ? > Been toying with the idea of making a small screen printing set up > but > no point in re-inventing the wheel if you've been there before! > AWEM > i do toner transfer it. wonder if colored toner would work in a bw printer and if it'd look even better. recenty experience adhesion problems on some board materials, greatly puzzled and annoyed by it. ST
2005-09-23 by ron amundson
> Has anyone got a homebrew set up working for > printing component > location overlays? Any tips and gotcha's ? > > Been toying with the idea of making a small screen > printing set up > but > no point in re-inventing the wheel if you've been > there before! > > AWEM > > Its rare that I will add the overlay, but I do have the capability of doing so. Here are a few things I found. 1. Use orange screen, as it reduces ghosting due to reflections as compared to white. (I still mostly use white, as its what I bought at the start) 2. One might get better results using sheet emulsion, but I have found that manually coating the screen works pretty well. The key is to only make one pass with the emulsion on front side, and then on the back side. If you make multiple passes, the emulsion gets too thick, and you loose resolution. 3. Be sure to refrigerate your emulsion... most of them have a short shelf life, and when they go bad, you run into big problems. 4. Don't be cheap when it comes to emulsion remover. While one can use bleach and scrubbing, the commercial removers work wonders, and I think are a lot easier on the screens. 5. A Stouffer gauge is a good investment, even for making PCB's. Spending $US18 for a strip of plastic seems insance, but it will save you tons of scrap screens, pcb's, and time... The 21 step is what was recommended to me, and its amazing. 6. Wash out your screen when you are done... if you wait around... it becomes pretty much permanent 7. scrap pcb's work well for registration 8. Water soluble inks make for ease of cleanup, but are not as robust as some of the solvent based inks 9. I use student grade art supplies, as most of the time, they are a lot safer than the industrial inks and solvents. 10. Currently, I make my films using ink jet printed transparencies. The black is not as opaque as would be nice for optimum resolution, so I am thinking of getting some ortho film or something like it. 11. Wood screening frames warp... but I have yet to find a good source of aluminum ones. A warped frame makes it a challenge to get decent resolution. Silkscreening just overlays is a ton of extra messing around for not a lot of value imho. However, you can also make up soldermask, solder stencils, and enclosure screens at the same time. The net result is you save a lot of time and increase reliability via reflowing the boards vs hand soldering, so imho its usually worthwhile. Ron __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com
2005-09-23 by Adam Seychell
Thanks Ron the informative reply. Silkscreening a one off PCB is like I figured, lots of messing around. I suspect it would add another hour to two of labor. I bought some silkscreen emulsion once, in a futile attempt to use it as a liquid photoresist for etching PCBs. First, I could not get thin even coatings, and 2nd the cured emulsion is not resistant to etchants (swells and lifts of copper). Just letting others no it ain't work. Adam ron amundson wrote:
>>Has anyone got a homebrew set up working for >>printing component >>location overlays? Any tips and gotcha's ? >> >>Been toying with the idea of making a small screen >>printing set up >>but >>no point in re-inventing the wheel if you've been >>there before! >> >>AWEM >> >> > > Its rare that I will add the overlay, but I do have > the capability of doing so. > > Here are a few things I found. > > 1. Use orange screen, as it reduces ghosting due to > reflections as compared to white. (I still mostly use > white, as its what I bought at the start) > 2. One might get better results using sheet emulsion, > but I have found that manually coating the screen > works pretty well. The key is to only make one pass > with the emulsion on front side, and then on the back > side. If you make multiple passes, the emulsion gets > too thick, and you loose resolution. > 3. Be sure to refrigerate your emulsion... most of > them have a short shelf life, and when they go bad, > you run into big problems. > 4. Don't be cheap when it comes to emulsion remover. > While one can use bleach and scrubbing, the commercial > removers work wonders, and I think are a lot easier on > the screens. > 5. A Stouffer gauge is a good investment, even for > making PCB's. Spending $US18 for a strip of plastic > seems insance, but it will save you tons of scrap > screens, pcb's, and time... The 21 step is what was > recommended to me, and its amazing. > 6. Wash out your screen when you are done... if you > wait around... it becomes pretty much permanent > 7. scrap pcb's work well for registration > 8. Water soluble inks make for ease of cleanup, but > are not as robust as some of the solvent based inks > 9. I use student grade art supplies, as most of the > time, they are a lot safer than the industrial inks > and solvents. > 10. Currently, I make my films using ink jet printed > transparencies. The black is not as opaque as would be > nice for optimum resolution, so I am thinking of > getting some ortho film or something like it. > 11. Wood screening frames warp... but I have yet to > find a good source of aluminum ones. A warped frame > makes it a challenge to get decent resolution. > > Silkscreening just overlays is a ton of extra messing > around for not a lot of value imho. However, you can > also make up soldermask, solder stencils, and > enclosure screens at the same time. The net result is > you save a lot of time and increase reliability via > reflowing the boards vs hand soldering, so imho its > usually worthwhile. > > Ron
2005-09-23 by Bob_xyz
Adam - What emulsion did you try and what was your etchant? I seem to recall a discussion on this topic recently but I'm not sure any conclusions came of it. Ron - Thanks for all the info on screening. Regards, Bob --- In Homebrew_PCBs@yahoogroups.com, Adam Seychell <a_seychell@y...> wrote: > Thanks Ron the informative reply. > > Silkscreening a one off PCB is like I figured, lots of messing around. I > suspect it would add another hour to two of labor. > > I bought some silkscreen emulsion once, in a futile attempt to use it as > a liquid photoresist for etching PCBs. First, I could not get thin even
> coatings, and 2nd the cured emulsion is not resistant to etchants > (swells and lifts of copper). Just letting others no it ain't work. > > Adam >
Hi Bob, it was a long time ago, but from what I remember the emulsion was nothing special, just common silk screen emulsion. Color was red and smelled a bit like PVA glue. After coating, drying, exposing and developing, the emulsion became quite solid and difficult to remove. However it would "swell" slightly in etchant, and I think somehow a microscopic amount of etchant would reach to the copper surface, causing the bond to break and it lifts off. Unlike photoresists, these emulsions don't seem to be completely impermeable to aqueous solutions. Adam Bob_xyz wrote:
> Adam - What emulsion did you try and what was your etchant? I seem > to recall a discussion on this topic recently but I'm not sure any > conclusions came of it. > > Ron - Thanks for all the info on screening. > > > Regards, Bob > > > --- In Homebrew_PCBs@yahoogroups.com, Adam Seychell > <a_seychell@y...> wrote: > >>Thanks Ron the informative reply. >> >>Silkscreening a one off PCB is like I figured, lots of messing > > around. I > >>suspect it would add another hour to two of labor. >> >>I bought some silkscreen emulsion once, in a futile attempt to use > > it as > >>a liquid photoresist for etching PCBs. First, I could not get thin > > even > >>coatings, and 2nd the cured emulsion is not resistant to etchants >>(swells and lifts of copper). Just letting others no it ain't work. >> >>Adam >> > > > > > > > > Be sure to visit the group home and check for new Links, Files, and Photos: > http://groups.yahoo.com/group/Homebrew_PCBs > > If Files or Photos are running short of space, post them here: > http://groups.yahoo.com/group/Homebrew_PCBs_Archives/ > Yahoo! Groups Links > > > > > > >
