Homebrew PCBs
Have you ever had PCB material that simply will not accept a toner transfer?
2005-11-03 by lcdpublishing
I am having the most difficult time trying to do toner transfer on
some circuit boards.  I have tried 15 different papers including a new
batch of Pulsar paper which isn't working either. I changed out the
toner cartridge on the printer.  I have tried about 15 different
settings on my iron for different temps.  I tried 3 different laser
printers (all that I have).  I just cannot get toner to stick to the
boards.
I have tried scotch bright, 400 grit paper, 600 grit paper, 1000 grit
paper, and 1200 grit paper.  I clean very thoroughly with acetone, I
don't touch the copper after cleaning, I don't touch the paper after
printing.
I am stumped and getting really frustrated - grrrrrr.
Sorry, had to vent.
Chris
Re: [Homebrew_PCBs] Have you ever had PCB material that simply will not accept a toner transfer?
2005-11-03 by Alan King
>boards.
>printing.
  Sounds like you've covered about everything else, the one thing I can
think of off hand is if you iron simply isn't hot enough.  10 is a
relative setting, if it doesn't have a high enough wattage, it may
simply not get the toner hot enough on the other side of the paper.
Try a different iron, or heat your oven to 300-350 ish, tape the paper
to the board, and toss the board in once it's hot.  Shouldn't take more
than a few minutes to get to temp. pull things out then use the iron
just to get some pressure while still hot.  Won't get a good board, but
if you get some ok transfer then you at least know everything else is
working ok..  Be careful and don't get burned.
Actually, from the discussion on hot plates etc, I'm going to try
straight on the stove.  The flat top stove I have has one of the best
heating element patterns I've ever seen, at least over a 1/2 diameter
section of the circular area.  Not to sure about pressing hard on the
ceramic top so going to use a bit of extra heat for testing..
Alan
Re: Have you ever had PCB material that simply will not accept a toner transfer?
Hi Alan, thanks for the reply.  I use a digital thermometer to
set/check the temp of the iron.  I have had great success at 380
degrees F so I always use that setting.  However, in the mess for
the last few days, I have tried anything from 240 degrees F all the
way up to 440 degrees F with about a 40-50 degree increment --- all
with the same results.
Darn this is frustrating, especially when the last few boards I did
were outstanding.  Oh well, tomorrow is another day and perhaps the
moon and the sun will be in the proper alignment again so I can get
good toner transfer to copper again.
Chris
I can
paper.
paper
more
iron
board, but
is
best
diameter
> Alan
2005-11-04 by Stefan Trethan
On Thu, 03 Nov 2005 22:26:21 +0100, lcdpublishing
> boards.
> printing.
> Sorry, had to vent.
> Chris
at that point i converted the fuser. but here it was only areas that
wouldn't stick.
st
Re: [Homebrew_PCBs] Re: Have you ever had PCB material that simply will not accept a toner transfer?
2005-11-04 by Alan King
>Chris
  Ok, with that said a few more things.  First, yes, I have some board
that sticks relatively poorly.  It is brighter than normal, and seems to
be staying bright, not sure if it's a coating or alloy of some sort.
With dozens of sheets on hand I bypassed it and haven't really given it
a second shot.  Note that if you even just took silicone spray, and
sprayed on a board, it would be very difficult to remove, even with
sandpaper etc, since it's inert.  It's why you do not ever ever ever use
silicone products on a car unless you don't want to be able to repaint
it, new paint will not stick properly and it's extremely difficult to
remove.  Coatings and alloys etc that might work fine within the normal
industrial PCB processes could conceivably make a board rather
unsuitable for transfer or very difficult to use..
  Get some of the Reynold's parchment paper, it's pretty well non-stick
itself.  You should get at least some to stay on the board with it, then
you can look at the toner to board bond a lot better.  After heat and
pressure, about the only thing left is the board itself.
  Actually the very best thing is to simply pre-etch the board.  Clean
it some first, then etch until it turns the rosy pink, then rinse with
distilled water.  The board surface should then be about as good as it
will ever get, so then try the transfer.  If it won't work after that,
no amount of other board prep is likely to work.
Alan
2005-11-04 by lcdpublishing
Hi ALan,
I tried pre-etching this morning and it may have helped.
After going through 12 sheets of Pulsar paper, I emailed them (Frank)
and he suggested I use a laminator rather than an iron.   THe unit he
recommended for .062" thick boards is $129.00 right now - I will wait
till they go on sale.
Anyway, back to my pre-etch.  On small test samples this proved to
help a lot.  I was testing traces from .005" to .100", even the small
ones were staying put.
However, as soon as I tried on a bigger board, the toner wouldn't
stick again -grrr.  The next time I am making boards - hopefully
tomorrow or Sunday, I will try a longer pre-etch to see if that helps
on the bigger boards.
Thanks again for all your help and suggestions!
Chris
Clean
with
it
that,
> Alan
