Homebrew PCBs
Motorized Stage and Stuff
2006-01-25 by scratch_6057
Starting to consider designing / building my own "Dremel"
Based CNC system and after dissecting a couple of Inkjet
printers and a flatbed scanner I just picked up at the
"GoodWill" store for $ 2.00 (yes two dollars) each,
I was looking for larger stepper motors when I came across
this Motorized Stage at Herbach and Rademan.
If I were to buy one I would consider changng it to a
stepper motor drive.
I thought some of you may be interested in taking a look at it.
< http://www.herbach.com/Merchant2/merchant.mv?
Screen=PROD&Store_Code=HAR&Product_Code=TM99MIS4349&Category_Code=MISC
If the link dosen't work, it's the first item under
" Miscellaneous Items " on the left hand menu at
BTW:
If you can get inkjet printerscheap or salvage, they have
nice slide rails with bushings and the scanner I got has
two parallel mounted slide rails (but only one side, the
side closest to the motor, has a bushing) and  the stepper
is geared to a cable and drum pull – pull transport drive
with an idler pulley at the other end.
Simple, elegant design very interesting.
Short URL's (was: Motorized Stage and Stuff)
2006-01-26 by soffee83
Scratch,
Sorry for the temporary subject change.:)
There's a couple sites, if you get those extra long links, you can go
there and paste them into a box and they'll code it into a nice little
short one.
I use this:        www.tinyurl.com
For instance, your's comes out to-> http://tinyurl.com/93cmd
Take Care,
                     George
PS- I learned long ago to cut and paste the ends of those long ones
when they get chopped off, but there's no telling what can happen to
them in transit. ;)
Re: [Homebrew_PCBs] Short URL's (was: Motorized Stage and Stuff)
2006-01-26 by Rick Hughes
--- soffee83 <soffee83@...> wrote:
> Scratch,
> links, you can go
> into a nice little
> short one.
Although less convenient at times, I believe using the
actual link address is better than resorting to a
service such as "tinyurl."  If "tinyurl" ceases to
exist, then all of the "tinyurl"'ed links in the
Homebrew_PCB message archive become worthless.
Just my 0.02,
Rick
2006-01-26 by Codesuidae
When you use full-length links, enclose them in '<' and '>' and usually
they will not be broken up, so they stay clickable:
<http://www.amazon.com/exec/obidos/external-search/103-5955052-4855039?field-keywords=mosfet&mode=blended&tag=mozilla-20&sourceid=Mozilla-search>
Dave K
