Homebrew PCBs
Direct to pcb printing
2006-04-25 by mycroft2152
i've been in contact with Volkan off list and had received samples of
the MIS ink on pcbs. The samples were for testing the individual inks
in etching baths.
Volkan painted the inks on the prepared copper then 'cured' at a high
temperature over a stove burner. Two layers of ink were coated on the
samples.
I tried 2 different etching baths, FeCL and HCl/H2O2.
The 4 inks (black, cyan, yellow, magenta) withstood the FeCl very well.
The HCl/H2O2 attacked the black and Cyan inks rendering them useless,
The Yellow and Magenta held up very well.
Some observations:
Curing is critical. Need to determind the exact conditions.
The 'painted' double layer is not representative of the printed
pattern. The thicker edges seem to be attacked more easily in the
etchants.
Some thoughts:
The inks are alcohol soluble. A little rubbing alcohol (isopropyl)
removed the inks. Note for cleaning up afterward.
Is it just the MIS ink clone formualtion of the Durabrite ink that
works? Were the MIS inks used because that was availible to Volkan at
the time? Would the Durabrite ink work?
Last night, I was able to print a few prepared flexible pcb's using
and Epson C66 printer with Durabrite ink. The print quality was very
good and the coverage ok with only slight beading on th solid blocks.
I used variosu settings for print qualtiy from the Epson control panel.
after 12 hours the Durabrite ink was still wet and smudged easily. The
next step in to put them in an oven, at variopus time/temperatures, to
cure. then etch.
Will keep you posted.
Myc
Re: Direct to pcb printing
2006-04-25 by lcdpublishing
Thanks for the update MYC, it is good to read about some positive
results!  The crude tests with durabrite inks did show they would
resist, but not very well.  However, my tests were very crude and I
didn't cure them in the oven - only hit them with a heat gun for a
few seconds or so (till I saw smoke).
chris
--- In Homebrew_PCBs@yahoogroups.com, "mycroft2152"
of
inks
> in etching baths.
high
> samples.
well.
useless,
> Some observations:
> etchants.
> Some thoughts:
at
using
very
blocks.
panel.
The
> cure. then etch.
> Myc
