Homebrew PCBs
Inkjet printing - it works!
2006-05-29 by Stefan Trethan
I managed to replicate Volkan's success with direct inkjet printing.
First i had to deal with the ink chips. I ended up soldering them together
in a stack (they are connected all parallel in the printer). I simply
stuck wires through the vias and made a stack out of them, also connecting
them to the little PCB carrying the contacts for them. This PCB is
attached to a section of ribbon cable that can be cut from the rest of the
head cable (don't slip with the knife!).
The really neat thing is one can simply pull the ribbon cable out of the
PCB now, and take the whole stack of chips to a resetter like
<http://www.eddiem.com/photo/printer/chipreset/resetchip.html> (make a
blind reset to reset the whole stack at once).
Now the the bloody printer shuts up about the chips being empty i could
find out why it would no longer print.
I found there was no ink whatsoever in the black cart. The whole fill must
have gotten out somehow. I have no idea how it managed that feat, looking
at the waste ink absorber i think it may have gone there, may... I
wouldn't know where else.
Anyway, i put a small amount of MISPRO ink into the black cart and the
head started to work just fine again.
I can feed a strip of PCB through, if stuck to a page horizontally so it
will go around the paper path bend.
Then i started to experiment with printer settings and got something that
worked after a while.
I must play with the settings some more since i still have some puddling,
and i must modify the paper path for PCBs and raise the head (currently it
is too close). But the pattern i printed could be etched just fine and
everything, just like Volkan says.
The vanishing ink problem must be resolved - maybe it is the "dry sponge"
refill method that is the problem. I should get a spongeless cart for this
printer.
When i'm confident the printer is no longer losing vast amounts of ink i
can fiddle with the settings some more to get things just perfect. I
noticed the different settings will affect resolution (too low and you see
banding just like with a old printer), ink amount (too much and you see
puddling), and color mixture. Some settings will use vast amounts of blue
color even though i print something black.
Anyway, i'm confident everyone can do it. The key is just a modern printer
with enough resolution to prevent the banding. The old models i tried
before had the nozzles too far apart they would form individual lines on
the (not wicking) copper.
I expect i can soon put the fuser for TT into long term storage. I hope to
find the usb cable later to do a scan.
ST
Re: [Homebrew_PCBs] Inkjet printing - it works!
2006-05-29 by Volkan Sahin
That's very good news. Expecting some images. Congratulations once again.
Volkan
..... find the usb cable later to do a scan.
ST
Be sure to visit the group home and check for new Links, Files, and Photos:
http://groups.yahoo.com/group/Homebrew_PCBs
If Files or Photos are running short of space, post them here:
http://groups.yahoo.com/group/Homebrew_PCBs_Archives/
Yahoo! Groups Links
Re: Inkjet printing - it works!
2006-05-29 by mycroft2152
Stefan,
Be careful the "But the pattern i printed could be etched just fine"
may come back and haunt you.
Why not go ahead an etch the board to actually duplicate Voltan's
success.
Remember based on Voltan's work, some inks are less stable in the
etchant than lhters
Myc
--- In Homebrew_PCBs@yahoogroups.com, "Stefan Trethan"
printing.
together
simply
connecting
is
rest of the
of the
(make a
could
fill must
looking
I
so it
something that
puddling,
(currently it
and
sponge"
for this
> printer.
ink i
I
you see
you see
of blue
printer
tried
lines on
hope to
> ST
Re: [Homebrew_PCBs] Re: Inkjet printing - it works!
On Mon, 29 May 2006 19:16:47 +0200, mycroft2152 <mycroft2152@...>
wrote:
> Stefan,
> success.
> etchant than lhters
> Myc
I didn't write that well.
It could be etched just fine should really read it was etched just fine.
ST
2006-05-29 by Mycroft2152
Great News!
Photos?
Myc
> <mycroft2152@...>
> wrote:
> > Stefan,
> etched just fine"
> duplicate Voltan's
> > success.
> less stable in the
> > etchant than lhters
> > Myc
> ST
> Home is just a click away.\ufffd Make Yahoo! your home
> page now.
http://us.click.yahoo.com/DHchtC/3FxNAA/yQLSAA/bGYolB/TM
> them here:
>     Homebrew_PCBs-unsubscribe@yahoogroups.com
Do You Yahoo!?
http://mail.yahoo.com
2006-05-29 by lcdpublishing
Hot Dog! That is great news!
I still have not gotten back to mine yet to "De-Jam" it.  Still too
mad to risk messing with it yet.
If resolution is important in this, then I should be in great shape.
This printer boasts a resolution of 5760 x 1440.
Congrats on the success!
Chris
Summation, Please-Was-Re: Inkjet printing - it works!
2006-05-30 by kilocycles
Stephan
Summing up, which printer and which ink did you use in your tests?
I went back and read the threads from the various posts on the
subject, and followed the links to the chip resetting info, and Epson
inkjet maintenance and modification articles.
Which Epson model or models should we look for at thrift stores, etc.?
 Do they have to be pigmented-ink printers to use the M16 ink (I think
that's the designation).  Also, are certain models easier to modify
for straight-through PCB travel?  An Epson was my first reasonably
high-quality inkjet printer a few years ago, but I've switched to
Canon.  I think the model I had was the 870.  I still have the
accessory photo-sized roll feeder for it.
Hopefully, as more of yours, Volkan's and others' work is successful,
a folder in the Files section will be established.
Great work, and I'm looking forward to seeing the photos!
Ted
together
connecting
of the
could
fill must
looking
so it
that
puddling,
(currently it
sponge"
for this
> printer.
ink i
you see
see
blue
printer
lines on
hope to
> ST
---snip---
