Homebrew PCBs
Temp Controller
Temp Controller
2006-08-24 by Andrew
Offer is still open for me to make a PCB to fit
your box dimensions.  Solder on an ATMEL and
a themrocuple sensor.  DO all the programming
and ship it off to you for free.
Will even include an ATMEL programmer so you
can flash any updates to the software you want
me to write.
I can even put in a 8x2 line LCD if that will
fit in your box (the 8x2 line is a standard
size I carry for one of my comercial projects)
You just need to make up the specs.
Re: [Homebrew_PCBs] Re: How not to control ovens
- was - The list is huge! Really huge!
Ok, so i went and bought that elektor article. Took
ages to sign up with that nonsense but in the end
i got the pdf. Anyway, there is a lot less
documentation than i would have hoped for. Not even
a flowchart for the software. I knew why i don't read
the elektor magazine.....
<SNIP>
Anyway, i'll have to think about this. I'm not feeling
well today and i just purchased an article that is of
less quality than many free projects on the web...
This seems way too complicated, i had hoped i could
use the thing more or less as-is but i'd have to
change so much.... damn it this should be a dead easy
problem to solve and it is getting more and more
annoying...
ST
Re: Temp Controller
Sorry all,
This was meant for ST and it went to the list :S
> me to write.
Re: [Homebrew_PCBs] Temp Controller
2006-08-24 by Stefan Trethan
> me to write.
You are crazy and i will not take advantage of you in that way ;-)
I might be interested in one of your displays, i searched and could not
find smaller ones than 16 character across.
How wide is the 8x2 one?
I am set up to programm atmels here, i'm just not very good with software
and it is a task i hate. However it would not be a problem to use software
someone else made and on a good day i might even be able to make small
changes.
How would you go about this? Have you read the elektor article? Would you
trash the eeprom? What atmel would you use? I assume you'd use the Maxim
TC interface IC? What control method would you use?
If you would not need the eeprom and used an atmel i can get that would
not be such a bad option.
The PCB does not worry me, that is quickly done.
I will see what that industrial controller does...
ST
2006-08-25 by guja
www.reichelt.de
LCD MO82 DIP 2x8 chars, no bl
  LCD 082 DIP 2x8 chars green led bl
  both 40x20mm
Get your own web address for just $1.99/1st yr. We'll help. Yahoo! Small Business.
2006-08-25 by Stefan Trethan
On Sat, 26 Aug 2006 00:17:38 +0200, guja <guja2001bg@...> wrote:
> www.reichelt.de
150 eur minimum order outside germany.
ST
2006-08-26 by guja
ok.
  how about
  http://www.rs-components.at
RS Bestell-Nr. 214-3480
RS Bestell-Nr. 214-3288
  On Sat, 26 Aug 2006 00:17:38 +0200, guja wrote:
> www.reichelt.de
ST
Do you Yahoo!?
 Everyone is raving about the  all-new Yahoo! Mail.
2006-08-26 by Stefan Trethan
On Sat, 26 Aug 2006 19:36:04 +0200, guja <guja2001bg@...> wrote:
> ok.
>   how about
That's 17 or 20 eur without VAT, more for the display than the whole oven
cost me.
Thank you, but the display problem is solved.
ST
2006-08-26 by Zoran A. Scepanovic
Hello Stefan,
>> ok.
>>   how about
> cost me.
> ST
  Poor Stef :)
  You are complaining on prices of components that Guja is pointing
  you to.
  Your monthly income much rxceedes Guja's and mine together for at
  least 2 times, but we're nos squeeking and squeeling on prices for
  the components that we have to obtain.
  Learn to use Photo process and stop throwing money on junk EPSON's,
  cheap printheads, ink,...
 Best regards,
 Zoran A. Scepanovic
 zastos@...
Be who you are and say what you feel because those who mind don't matter and those who matter don't mind.
Please be advised what was said may be absolutely wrong, and hereby this disclaimer follows.  I reserve the right to be wrong and admit it in front of the entire world.
On Sat, 26 Aug 2006 21:01:53 +0200, Zoran A. Scepanovic <zastos@...>
wrote:
>  Poor Stef
>   you to.
I do not appreciate this post.
You make wrong assumptions and tell me what to do, i don't like that.
ST
2006-08-26 by Myc Holmes
Aww Stefie, lighten up..You are forever "recommending" others to do things.
Turn about fair play.
Myc
> wrote:
> >  Poor Stef
> >   you to.
> ST
> Be sure to visit the group home and check for new Links, Files, and
> Photos:
> http://groups.yahoo.com/group/Homebrew_PCBs
> If Files or Photos are running short of space, post them here:
> http://groups.yahoo.com/group/Homebrew_PCBs_Archives/
