Homebrew PCBs
Drilled solder paste stencils
2006-10-23 by derekhawkins
Another use for a CNC drill or mill. Goodbye to hand soldering,
syringes and $100 - $150 laser templates. Some after "pasting" and
after "baking" shots are at the link below. Click on slideshow in the
upper right hand corner.
http://www.pbase.com/eldata/stencils&page=all
Re: [Homebrew_PCBs] Drilled solder paste stencils
2006-10-23 by Alexandre Guimarães
Hi, Derek
    Can you give more details of the process ? Things like material used for
the stencil, drill sizes, how to fix the plate for drilling, how to fix the
plate for applying the solder paste, down to align the plate and the
PCB..... Those details will be very helpfull for anyone tryong to reproduce
your efforts.. I will surely try :-)
Best regards,
Alexandre Guimaraes
2006-10-23 by Steve Wiseman
That's rather impressive. Did you do anything special to flatten the
stencil after drilling? (or do you just use sharp drill bits?)
Steve
2006-10-23 by Sander Pool
Nice work! Looks like the template was sanded to deburr the holes. Must
be pretty tricky to keep sheet metal flat enough to keep it in contact
with the PCB. I assume you clamp them together and then scrape paste in
each hole with a putty knife of some sort?
    Sander
> Steve
Re: Drilled solder paste stencils
2006-10-23 by Andrew
> to hand soldering, syringes and $100 - $150
> Click on slideshow in the upper right hand
> corner.
Couple the CNC with some thin stainless and
an EDM unit and square holes are on the cards.
Re: [Homebrew_PCBs] Re: Drilled solder paste stencils
2006-10-24 by Steve Wiseman
Well, yes, you could - but round holes seem to do the job nicely without
the extra pain...
Steve
2006-10-24 by derekhawkins
Google >"Drilling solder paste stencils"<
Check out this link and website;
http://www.stencilsunlimited.com/images/StencilTapedAndOpen.jpg
--- In Homebrew_PCBs@yahoogroups.com, Alexandre Guimarães <listas@...>
2006-10-24 by scratch_6057
WONDERFULL!
How thick is the brass material?
Did you have the brass clamped between sheets of something? What?
.007"
No.
--- In Homebrew_PCBs@yahoogroups.com, "scratch_6057" <dml.empsrch@...>
.007"
No.
2006-10-28 by william.kroyer@kilroysprojects.net
"Sweet" would just about sum up my thoughts on that.  Nice work.
  Sent: Sunday, October 22, 2006 11:31 PM
  Subject: [Homebrew_PCBs] Drilled solder paste stencils
