Homebrew PCBs
mini-project done, and cleaning no-clean flux
2006-11-26 by DJ Delorie
Just finished a mini-project:
        http://www.delorie.com/pcb/r8c-1b-adapter/
This is a toner transfer board.  I used the wiping trick for etching,
a little different than last time.  I poured a bit of FeCl into a
small plastic tray, and dipped a sponge into it.  I wiped the copper
with the soaked sponge, but this time I occasionally squeezed out the
used FeCl and soaked up more (same tray, so not "perfectly" clean, but
at least cleaner).  The copper etched much faster this way (last time,
I poured the FeCl into the sponge, so there was no opportunity to
refresh it).
Question: I'm using Kester SP-44 flux, the no-clean type.  I use NC so
I don't have to worry about what's under parts, but I'd still like to
"pretty up" the exposed board by removing the spent flux.  Ideas?
What works on the flux, but doesn't damage the parts?  I've got
xylene, a water pic, and rubbing alcohol available to me.
DJ
Re: [Homebrew_PCBs] mini-project done, and cleaning no-clean flux
2006-11-27 by Leon Heller
To: <Homebrew_PCBs@yahoogroups.com>
Sent: Sunday, November 26, 2006 11:54 PM
Subject: [Homebrew_PCBs] mini-project done, and cleaning no-clean flux
> refresh it).
Rubbing alcohol is basically IPA, so it should be OK. Xylene works OK as
well, but the fumes aren't very nice.
Leon
2006-11-27 by DJ Delorie
"Leon Heller" <leon.heller@...> writes:
Ok, thanks.
> Xylene works OK as well, but the fumes aren't very nice.
Yeah, I do that outside.  It's the same stuff I use to remove the
toner.  I just worry it will dissolve the SMD parts (for this board,
one cap and one crystal).
Sent: Monday, November 27, 2006 2:52 AM
Subject: Re: [Homebrew_PCBs] mini-project done, and cleaning no-clean flux
I forgot to mention that it might contain oil of wintergreen, which will
leave an oily residue. Pure IPA is best, and is easy to obtain from
electronic suppliers.
Leon
Leon Heller, G1HSM
Suzuki SV1000S motorcycle
leon.heller@...
http://www.geocities.com/leon_heller
Sent: Monday, November 27, 2006 7:56 AM
> From: "DJ Delorie" <dj@...>
Another option that works well is plain hot water. I remember once visiting
a company that used a dishwasher for cleaning their boards.
Leon
2006-11-27 by Stefan Trethan
On Mon, 27 Nov 2006 11:12:16 +0100, Leon Heller
> visiting
> Leon
With some circuits you need de-ionized water. Many companies use ion
exchangers for that, i believe the water softening ion exchanger in the
dishwasher will not be enough.
ST
2006-11-27 by Roland Harriston
Leon Heller:
Was that company, by any chance, Scientific Audio Engineering
in Los Angeles California. They manufactured the famous
SAE audio equipment.
Roland F. Harriston
> visiting
> Leon
Sent: Monday, November 27, 2006 11:51 AM
> Leon Heller:
No, it was a company in Crawley, UK, IIRC.
Leon
Re: [Homebrew_PCBs] Dish Washer PC Board Cleaning
Leon Heller:
Thanks for the response. SAE used to employ an ordinary dish washer
to clean PC boards after they came off  of the wave soldering machine.
I don't recall what kind of soap they used!
Roland F. Harriston
On Mon, 27 Nov 2006 14:22:05 +0100, Leon Heller
>> Leon Heller:
> Leon
I've heard it a few times now, many companies must do the same.
ST
On Mon, 27 Nov 2006 14:38:36 +0100, Roland Harriston <rolohar@...>
wrote:
> Leon Heller:
> Roland F. Harriston
Detergent for manual dish washing (usually green) seems to work for people.
The dish washer stuff is quite agressive.
ST
2006-11-27 by Syd H. Levine
Tektronix used to run test instrument guts thru a dishwasher when they did refurbs.
  Sent: Monday, November 27, 2006 8:38 AM
  Subject: Re: [Homebrew_PCBs] Dish Washer PC Board Cleaning
  Leon Heller:
  Roland F. Harriston
Sent: Monday, November 27, 2006 3:47 PM
> refurbs.
The old 541 scopes were dunked in a large vat of hot detergent.
Leon
Ok, the two alcohols I have are both 70% alcohol, with nothing else
but water.  They got off most but not all of the residue.  The water
pic didn't do much for the remainder.  Xylene helped a little, but
there's still residue.
Time to email the manufacturer, I suppose.
Syd H. Levine:
Yes, come to think of it, I have heard that Tektronix did that sort of thing
when they did refurbs on oscilloscopes. I think they did some of that at
the facility in Orange County, California.
Roland F. Harriston
Sent: Monday, November 27, 2006 4:37 PM
The IPA I use is 99.7% pure. It's made by Electrolube.
Leon
Re: [Homebrew_PCBs] Isopropyl Alcohol 90%
I can always find 90% isopropyl alcohol at my local Walgreens drug
emporium or
at the  Safeway supermarket. I'm quite sure that this material is widely
available.
A 16oz  bottle  is worth about a  dollar.
The stuff is water clear with no additives. I also see on the shelves a
"Rubbing Alcohol" that is tinted green and  it contains some other
ingredients, perhaps wintergreen or some such.
I've been using  90% isopropyl for many years as a general purpose
cleaner.
It is relatively safe, although flammable, and the fumes are
not too nasty.
Roland F. Harriston
> <mailto:leon.heller%40bulldoghome.com>> writes:
> will
Re: mini-project done, and cleaning no-clean flux
2006-11-27 by jpanhalt
I use a 2:1 mixture of absolute ethyl alcohol and acetone.  The
acetone is probably not necessary and does evaporate over time, but
the removal speed is excellent.  Just dip it, wipe with a towel or
toothbrush, and the the flux is gone.  The acetone also attacks
certain plastics, but not the epoxy used for ICs or PCBs.  I used
absolute ethyl alcohol because it was readily available to me.
Denatured alcohol would probably work just as well, as would 100% IPA
(isopropyl alcohol), as has been already suggested.  But, the latter
is hard to find locally.  That is probably because it is not as good
an antiseptic as 50% or 70% IPA, which is the usual consumer use for
it.  Come to think of it, E95 might work too, but I haven't tried it.
I think keeping water out of the solvent is probably important,
unless the flux is water soluble or you use heat and a detergent. John
Hmmm... I'll have to check all the containers I've got, one of them
might be useful.  I've got some denatured alcohol, but I'm not sure
what the additives would do to the board.
2006-11-27 by Lez
>  emporium
Thought that was a posh London store then I saw you put
So yes I may be on a winner we have safeway in the UK
Ahh, they must be a safeway company in the US
>  not too nasty.
And not generally sold in the UK, especially since vinyl records have
been replaced by cd's
Its _really_ hard to buy anything in the UK thats not a food product,
even strong toilet cleaners are becoming rare! (they dont want us
making bombs etc)
Lez
My dad used to have a 5 gal bucket of something called "electrical
cleaner" which was specifically designed to be safe for cleaning
electrical stuff.  I have no idea what was in it, though.
2006-11-27 by Bert
I get 91% for cheap at either target or WalMart and it owrks for most
general purpose applications. No good for things like video heads and
other sensitive applications though.
I used to always get 99% at the local Snyders Drug store for still a
reasonable price (few bucks for a pint). I haven't checked recently
(still have quite a lot on hand) but I think they still sell it. If
it's not on the shelf, ask at the pharmacy counter. I'm sure they can
order it and Snyders has always been easy to work with.
which will
Re: [Homebrew_PCBs] Re: mini-project done, and cleaning no-clean flux
I was wondering, can one accurately measure the purity of IPA or ethanol
by measuring the density?
Like measuring volume and weight, or using a hydrometer?
I recently found a 0-100% ethanol hydrometer, but i'm wondering if the
measurement would tell me much, what if the other ingredients are not
water? What if they have a density other than 1kg/l, then the measurement
would not tell me the purity?
ST
Stefan Trethan:
I just rechecked the new bottle of iso that I recently purchased from
Safeway supermarket,
and it is 99% iso alcohol,  not 90% as I might have stated previously.
Honestly,  I don't think that for the purpose of cleaning off home-made
printed circuit boards,
the character and integrity of the iso alcohol that one uses is of any
great significance insofar
as purity is concerned. If one is doing work for NASA or some Hi-Rel
defense system, then
doing the analysis might be important. And even in those cases the
vendor of the material would
most likely supply you with those types of quality data.
Better to spend that time making good, clean PC layouts
for your projects.
Besides who has all that lab equipment, and who wants to work to the
degree of cleanliness
required to make the measurements meaningful??
This stuff is supposed to be fun!
Just my opinion.
Roland F. Harriston
> ST
> http://groups.yahoo.com/group/Homebrew_PCBs
> If Files or Photos are running short of space, post them here:
> http://groups.yahoo.com/group/Homebrew_PCBs_Archives/
On Mon, 27 Nov 2006 21:53:30 +0100, Roland Harriston <rolohar@...>
wrote:
> Stefan Trethan:
> for your projects.
> Just my opinion.
> Roland F. Harriston
Well, that doesn't change my curious nature ;-)
The only reason i have not yet used the hydrometer is because i don't have
a suitable container to float it in. The thing is precise and quite high
(about what you'd call a foot). A foot high of alcohol is quite a lot so i
need a narrow container.
But one day i'll find the right glass for it, and then i'll need to know
what the measurement actually means (if it is likely the contaminants are
water or not).
ST
Roland Harriston <rolohar@...> writes:
> home-made printed circuit boards, the character and integrity of the
> iso alcohol that one uses is of any great significance insofar as
Unless, as one person noted, "water just makes the flux sticky".  If
so, you'd want to have the least amount of water in the alcohol so as
to avoid that.
Re: Dish Washer PC Board Cleaning
2006-11-27 by Andrew
A bucket full of CFCs.
Ah I can hear the ozone dying as we speak :D
RE: [Homebrew_PCBs] Re: mini-project done, and cleaning no-clean flux
2006-11-27 by Randy Ledyard
Stefan
Yes you can, as long as we're talking a simple binary mixture of IPA and
H2O. After that is gets complicated real quick....
Density of IPA (also known as 2-Propanol) is 0.7855 g/ml @ 20C
Density of H2O is, of course, 1 g/ml
If you can measure the volume and the weight of the mixture, you can
calculate the density of the mixture
From this you can get the ratios of the components
Let me know if you need more info on how to arrive at the ratios
Randy
> From: Homebrew_PCBs@yahoogroups.com
> [mailto:Homebrew_PCBs@yahoogroups.com]On Behalf Of Stefan Trethan
> Sent: Monday, November 27, 2006 2:33 PM
> Subject: Re: [Homebrew_PCBs] Re: mini-project done, and cleaning
> no-clean flux
> measurement
> ST
2006-11-28 by Stefan Trethan
On Tue, 28 Nov 2006 00:35:27 +0100, Randy Ledyard
<rll_groups@...> wrote:
> Stefan
> Randy
Thank you, I understand that.
What i was asking is if there are likely contaminants far off the density
of water.
I have no means (and no intention) to analyze it exactly, but there is no
point in going through with the hydrometer measurement if the result is
meaningless.
I've weighed a bottle of IPA a while ago, using an identical bottle filled
with water to the same level to determine the volume. But this process was
not very accurate. Now that i found the ethanol hydrometer, i could use
that (observing the tiny correction factor between IPA and ethanol).
ST
2006-11-28 by AnaLog Services, Inc.
The common stuff is only about 70%, but you can get the 91% at Wal-Mart and elsewhere for a few cents more.  The balance of the mix is of course water.  I have never been impressed with IPA as an electronics cleaning material (the expensive anhydrous stuff sucks also)..  Ethanol is a much better cleaner.  The denatured stuff stinks, but it just has a little methanol added to make the whinos go blind.  If you want really good Ethanol, go to the liquor store and buy Everclear (PGA).  We have been using it as flux cleaner here ever since they outlawed our 1,1,1.  One caution:  ethanol will attack some of the nastier plastics like styrene; it does not bother typical PCB material at all.
http://www.logwell.com/editorials/1-1-1.html
Syd
  Sent: Monday, November 27, 2006 1:02 PM
  Subject: Re: [Homebrew_PCBs] Isopropyl Alcohol 90%
  emporium or
  available.
  cleaner.
  not too nasty.
  Roland F. Harriston
  > will
Re: [Homebrew_PCBs] Re: Dish Washer PC Board Cleaning
Prolly 1,1,1.  I bet that fella was single handedly responsible for environmental catastrophe.
  Sent: Monday, November 27, 2006 5:09 PM
  Subject: [Homebrew_PCBs] Re: Dish Washer PC Board Cleaning
2006-11-28 by Lez
wrong side of the pond m8y.
Our 'wal-mart' is www.asda.co.uk
We dont 'sell' chemicals over here.
IPA is like at a chemists only, and they ask questions, and mine does
not sell it anymore, except in 25ml tubs for about $4 (£2)
I bet someone will post and prove me wrong, but if its not used for
cleaning your car, or for granny to bake with, its not on sale over
here.
We do have 'specialist' chemical supply companys with big metal drums
often seen exploding in movies, but they would want to know why I need
so much, and could I afford it, then they would want to know how I was
going to store/use it.
When I wanted to paint my car, I went to buy 10ltrs of paint, and was
refused it as I was going to paint it without the required ventilation
equipment....(I did get some at another supplier)
Even our drain cleaners are nearly getting safe enough to drink.......
Lez
On Tue, 28 Nov 2006 01:32:54 +0100, AnaLog Services, Inc.
I've yet to observe ethanol attack styrene, but maybe the additives are
different in some places for denatured. I use mine on all plastics with no
hesitation.
I agree with you that IPA seems to have less cleaning action, and it
stinks like a doctors office. Denatured ethanol OTOH tastes _really_ bad,
no i don't try to drink it but if you blow out a tubular part a tiny
amount of residue tastes very bad on your lips. Same with antifreeze, and
intentional in both cases.
ST
2006-11-28 by Syd H. Levine
Ethanol will most definitely attack polystyrene and its cousins.  If you
have not noticed it, it is because you have not been handling true
polystyrene.  It does not attack most other plastics.  My paper towel
dispensers in the shop are polystyrene, and if my fingers are wet with
ethanol, they will stick to the darn things and leave fingerprint marks.
Sent: Monday, November 27, 2006 7:54 PM
> hesitation.
> ST
> Photos:
2006-11-28 by Leon Heller
Sent: Tuesday, November 28, 2006 12:49 AM
> and
not sell it anymore, except in 25ml tubs for about $4 (\ufffd2)
The 99% stuff is available from RS, Farnell and Rapid Electronics in 1l
cans.
Leon
On Tue, 28 Nov 2006 06:43:34 +0100, Syd H. Levine
I'll try again then!
Did you use pure ethanol or a denatured variety?
ST
I just tried, with a solid polystyrene cup (marked), expanded polystyrene
foam (marked), and ABS.
None of these plastics shows any reaction whatsoever, when exposed for
like a minute or so. I have rubbed the ethanol around with my finger and
there was no stickyness, nor was there any surface disturbance after
drying.
So you are either mistaken (solvent not ethanol or towel holder not PS),
or your ethanol is denatured with something agressive. I was told they
used to denature it with petrol in some places.
I'm sorry, but it's just not happening. I have used different brands of
denatured ethanol here for at least 10 years, regularly on ABS and PS with
no adverse effects. Some of my parts boxes are styrene plastic, and i
remove obsolete markings all the time with ethanol.
ST
Either is aggressive against polystyrene.  For instance, those white foam
expanded polystyrene cups cannot survive PGA (as if anybody could stand to
drink it straight).
I have gotten away from the denatured stuff due to the stink.  I buy bottles
of PGA (Everclear) and use it for flux cleaning.  I pay the outrageously
high tax on it that way, but I use so little, it is much easier to do that
than to buy it from a chemical supplier.
Syd
Sent: Tuesday, November 28, 2006 4:58 AM
> ST
> Photos:
On Tue, 28 Nov 2006 13:06:09 +0100, AnaLog Services, Inc.
> to
> drink it straight).
> bottles
> that
> Syd
Then you must have different polystyrene than we have. Ethanol does
nothing to mine.
ST
Most peculiar.  I originally noticed this with denatured alcohol.  The
denaturing agent is usually methanol.  I *THINK* I have seen the same effect
with PGA ethanol, but now I am questioning my sanity.  I will do some
experimenting down in the lab later today.
I did come across a mention of 0.37% solubility of polystyrene cup material
in PGA, but not much else with a web search.
Sent: Tuesday, November 28, 2006 5:15 AM
> drying.
> ST
> Photos:
On Tue, 28 Nov 2006 13:44:32 +0100, AnaLog Services, Inc.
> effect
> material
Polystyrene foam cups are virtually non-existent here. I can't remember
ever seeing one in my life.
Coffee machines use polystyrene cups, but not foam, they are vacuum formed
sheet with a rolled edge, or some cardboard polyethylene composite
material.
But still, expanded or extruded polystyrene should be the same all around
the world, since it is shipped as packing material everywhere. My ethanol
did not do anything to that, or vacuum-formed sheet polystyrene cups.
Acetone or laquer thinners will eat all that though.
ST
2006-11-29 by Peter Harrison
>> effect
>> material
> material.
> ST
I would suggest you may both be right. I was curious about this so I
popped down to the garage and tried some polystyrene foam in both IPA
and denatured ethanol. Neither had any noticeable effect upon the
polystyrene foam. This is perfectly reasonable. Imagine a world where it
was not possible to go to those classy parties where you get to drink
beer and wine from polystyrene cups for fear that they dissolve in your
hands.
On the other hand, the monomer styrene is soluble in ethanol apparently.
  see http://www.oehha.ca.gov/air/acute_rels/pdf/100425A.pdf
but should not be present in any quantity in polystyrene. I really don't
know how much might be there. The styrene monomer is toxic. Table 6 in
this paper:
http://www.mindfully.org/Plastic/Polystyrene/Polystyrene-Foods-Styrene-Monomer.htm
indicates that even then, the amount of styrene you would get out is
tiny and that the polystyrene cup is not destroyed in the test.
If Everclear - which claims to be a non-toxic ethanol product - really
can dissolve polystyrene I would be worried either about the quality of
the polystyrene or exactly what can be present in small proportions in
Everclear that can wreak such havoc with polystyrene.
Pete Harrison
Re: Isopropyl Alcohol 90%
2006-11-29 by Steve
--- In Homebrew_PCBs@yahoogroups.com, "Stefan Trethan"
are
with no
> hesitation.
Denatured alcohol has methyl alcohol added, and denatured -does-
attack styrene, albiet very slowly. Most VCR front panels are/were
made of styrene. IPA wipes crayon off of it very well, denatured works
even better but you'll end up with bits of fluff from your rag welded
into the top layer of plastic.
Now things are made of different kinds of plastic, usually painted.
Steve Greenfield
2006-11-29 by Stefan Trethan
On Wed, 29 Nov 2006 01:14:48 +0100, Peter Harrison
> hands.
How could both be right? Either is is attacked significantly or it isn't.
I can't see no effect of ethanol on styrene and i'm tired of hearing those
claims without any proof.
ST
Re: [Homebrew_PCBs] Re: Isopropyl Alcohol 90%
> Steve Greenfield
I think our denatured here just has no methanol then.
I find most electronics plasticwork is still ABS.
ST
On Wed, 29 Nov 2006 02:30:23 +0100, Stefan Trethan <stefan_trethan@...>
confirmed, german MSDS list 1% MEK (and or other ketones and maybe tiny
amounts of other denaturing agents) and english MSDS 5% methanol.
While MEK will solve some plastics the lower concentration and/or it's
difference to methanol in agressiveness seems to explain the discrepancy
in observations.
I'm satisfied that's the reason, maybe it's why IPA is so widely used in
the US while here denatured ethanol replaces it in almost all capacities.
If denatured alcohol solved plastics it would have fallen out of favour
quickly.
Good night.
ST
2006-11-29 by Syd H. Levine
Steve:
Is it the methanol additive doing that?  My experience is that it will actually smear clear polystyrene windows like you describe (and stick the fuzz particles to it).  I was pretty sure pure ethanol was doing it too, but now I am questioning that.
  Sent: Tuesday, November 28, 2006 8:11 PM
  Subject: [Homebrew_PCBs] Re: Isopropyl Alcohol 90%
  are
  with no
  > hesitation.
  Steve Greenfield
I found a good chemical compatibility table indicating ABS (a common styrene
based plastic used in electronics) is severely attacked by Methanol, but
only very slightly attacked by Ethanol.  Methanol is the common denaturing
agent in the US and this probably explains my experience with denatured
alcohol attacking styrene based plastics.
I have not had a chance to test some PGA (Everclear) on ABS, but I am now
assuming I was merely extrapolating my experience with the denatured
ethanol.  I must have never actually tried the PGA, but simply assumed it
acted the same way as the denatured stuff.  This also makes me wonder if
Methanol might actually make a good flux cleaner since I have had a nagging
suspicion that the denatured alcohol actually works a bit better as a flux
cleaner than the PGA.  But not really sure about that observation.
As to the denaturing agent being Methyl Ethyl Ketone (MEK) in Europe, that
is rather interesting.  MEK is VERY aggressive against ABS and PVC.  It
would be hard to believe that Ethanol denatured with MEK would not be as bad
as Ethanol denatured with Methanol with respect to attacking ABS.
Syd H. Levine
Phone:  (270) 276-5671
Telefax:  (270) 276-5588
E-mail:  analog@...
Web URL:  www.logwell.com
Sent: Tuesday, November 28, 2006 8:17 PM
>> hands.
> ST
> Photos:
On Wed, 29 Nov 2006 10:17:30 +0100, Syd H. Levine
> that
> bad
I can not be sure if it is is my denatured ethanol, since i do not have a
MSDS for the brand i currently use. But all MSDS i've downloaded listed
MEK, and i used several brands over the years, so it is highly likely some
if not all contained MEK.
I have used it on ABS countless times, and never observed any trouble like
surface damage in any way.
Maybe the low percentage renders MEK harmless.
ST
As a rule, mixing solvents is fairly predicable.  There are exceptions, so
maybe MEK does not act as aggressively as Methanol as a small percentage of
the mix with Ethanol.
Note that MEK is often the principal agent in ABS and PVC pipe cleaners, and
maybe in the solvent cements themselves.  MEK is nasty stuff.
Sent: Wednesday, November 29, 2006 4:50 AM
>> that
>> bad
> ST
> Photos:
2006-11-29 by D
--- In Homebrew_PCBs@yahoogroups.com, "Syd H. Levine" <wireline@...>
styrene
but
denaturing
There are a BUNCH of different denaturing agents used for ethanol
in the US.  The authoratative list is here:
http://www.access.gpo.gov/nara/cfr/waisidx_06/27cfr21_06.html
Some of those things are pretty nasty, even nastier than methanol
or MEK!
am now
assumed it
wonder if
nagging
a flux
Europe, that
be as bad
> Syd H. Levine
> E-mail:  analog@...
Dave
2006-11-29 by Steve
From what others are saying, I suspect that it's either the methanol,
or there are some other additives to denature it that mildly eat into
some plastics.
Steve Greenfield
wrote:
> Steve:
2006-11-29 by AnaLog Services, Inc.
Yes, that does appear to be the case.  I just tested PGA on some ABS, and there is no detectable degradation.  The denatured material I have causes marked damage to susceptible plastics.
The denaturing agent is NOT Methanol alone I now see from the federal regulation which states the formulas for Completely Denatured Alcohol.  If it comes from Lowes, Wal-Mart, a paint store, etc., it can only be one of the CDA formulas.  And that means it will have some gasoline or kerosene in it, and possibly a number of other nasty ingredients.  Looking at the formulas for CDA is a real eye-opener!  I will never use the denatured product again for flux cleaning.
This has been an educational experience.  Thank you for making me re-examine something I thought I understood.
Syd H. Levine
Phone:  270-276-5671
Telefax:  270-276-5588
E-mail:  analog@...
  Sent: Wednesday, November 29, 2006 1:30 PM
  some plastics.
  Steve Greenfield
  wrote:
  > Steve:
2006-11-30 by Herbert E. Plett
--- "Syd H. Levine" <wireline@...> wrote:
> ...  My paper towel
usually they are ABS...
styropor (or whatever brand) is 'pure' foamed styrene. is this attacked?
Cheap talk?
Check out Yahoo! Messenger's low PC-to-Phone call rates.
http://voice.yahoo.com
2006-11-30 by AnaLog Services, Inc.
It is now clear that PGA (Everclear) ethyl alcohol (ethanol) only very mildly attacks polystyrene.  It does not noticeably attack ABS, but is listed as very mildly aggressive.  My PGA test on my paper towel dispenser showed no noticeable effect.  My confusion stemmed from what is in denatured ethyl alcohol.  It is denatured with a variety of crap, some of which will attack ABS.
  Sent: Wednesday, November 29, 2006 10:53 PM
  > ... My paper towel
  Cheap talk?
2006-11-30 by Stefan Trethan
On Thu, 30 Nov 2006 04:53:22 +0100, Herbert E. Plett <cachureos@...>
No, not when applying a small puddle in a depression and rubbing it
around. No softening, no stickyness, nothing, with my (european) denatured
alcohol. Vacuum formed polystyrene cups (white, solid no foam, for dairy
products) also show no reaction either. I believe they are also plain
polystyrene.
Seems a bit silly to me to denature it with something that dramatically
reduces it's applications. May be why IPA is used in the US instead.
ST
2006-12-01 by AnaLog Services, Inc.
Many thanks to Stefan for making me examine an incorrect belief I have long
held about Ethanol.  I have revised my pages on Ethanol as a cleaner, and
added a page on the formulas used here in the US.  It would be interesting
to know the actual formula for the denatured alcohol that Stefan is using.
Clearly the stuff sold as denatured alcohol here in the US is nasty stuff,
and it will definitely attack ABS.  True PGA is next to harmless on ABS.
http://www.logwell.com/tech/servtips/cleaning.html
http://www.logwell.com/tech/servtips/CDA_formulas.html
Syd H. Levine
E-mail:  analog@...
Sent: Thursday, November 30, 2006 9:15 AM
> polystyrene.
> ST
> Photos:
2006-12-01 by Stefan Trethan
On Fri, 01 Dec 2006 17:52:30 +0100, AnaLog Services, Inc.
> long
> interesting
> using.
> stuff,
> Syd H. Levine
> E-mail:  analog@...
I'm also glad the mystery is solved, i was starting to believe some people
must have been drinking the ethanol when it attacked their plastics, but
you guys are not crazy after all, it is just your suppliers mixing nasty
stuff in there rendering it useless.
I will pester the chemicals shop people until they surrender either the
name of the supplier or the denaturing agent, i promise. But i will have
to wait until i need to make a purchase, to aid in loosening their tongue.
They dispense all chemicals in the shop from larger tanks so i do not know
what manufacturer it comes from. It may even be different from the usual
stuff that you get in DIY stores.
I have used denatured ethanol in a tin can from a paint manufacturer
before, and it was the same on plastic. But i can't find a MSDS for that
brand.
ST
