gas soldering irons
2007-01-24 by David McNab
Hi, (For those of us still stuck with manual soldering) I've just been trying out a cheap (USD$18) gas-powered soldering iron (actually USD$14.50 with trade discount). First impressions are excellent - beats the hell out of my mains electric iron. Goes even better after filing the tip to a sharp fine point. Surprisingly, it easily gets enough heat to the very tip to melt solder quickly and make a fine clean joint. I'm getting performance comparable to or better than the Weller stations I've used in the past. This kicks down another barrier to my eventual move to SMD. The only downside I've seen so far is the need to be aware of where the exhaust hole is pointing :P Cheers David
