Homebrew PCBs
resist
resist
2007-02-27 by wnnelson0
Here is a article on printing photo resist. Why would they deposit
photo resist instead of a direct resist.
R��sum�� / Abstract
This article presents a technique for resist deposition using a
novel fluid ejection method. An ejector has been developed to
deposit photoresist no silicon wafers without spinning. Drop-on-
demand coating of the wafer reduces waste and the cost of coating
wafers. The novel piezoelectric fluid ejector is based on a
variation of the design of a flextensional transducer that excites
axisymmetric resonant modes in a damped circular membrane. The
ejector is made by bonding a thin piezoelectric ring to a thin,
fully supported, circular membrane. The ejector design is optimized
for maximum flexure at the lowest order resonant frequency using
finite element modeling. The resist, is placed behind one face of
the membrane which has small orifice (50-150 ��m diameter) in its
center. By applying an ac signal across the piezoelectric element,
continuous or drop-on-demand ejection of the resist is achieved.
Shipley 1400-21, 1400-27, 1805, and 1813 resists were used to coat
sample 3 wafers. Later, these wafers were exposed and developed. The
deposited resist film was 3.5 ��m thick and had a surface roughness
of about 0.2 ��m. The ultimate goal is to deposit resist films with a
thickness of the order of 0.5 ��m, and a surface roughness of the
order of 30 A��. Such goals can be attained by using micromachined
multiple ejectors presently under development, or with better
control liver the deposition environment. In the micromachined
configuration, thousands of ejectors will be made into a silicon die
and thus allow for full coating of a wafer in a few seconds. Coating
in a clean environment will allow the lithography of circuits for
microelectronic applications
Re: [Homebrew_PCBs] resist
2007-02-27 by Stefan Trethan
On Tue, 27 Feb 2007 17:25:15 +0100, wnnelson0 <wnnelson@...>
Most likely because the resolutions needed for making ICs are higher than
what they could print directly.
ST
Re: resist
--- In Homebrew_PCBs@yahoogroups.com, "Stefan Trethan"
than
> ST
So the photo resist is easier to deposit in finer resolution? Why? How
about if we try this too?
Re: [Homebrew_PCBs] Re: resist
On Tue, 27 Feb 2007 18:35:25 +0100, wnnelson0 <wnnelson@...>
No, they seem to apply an even film, and then photoprocess it like normal.
Looks to me as if they are saying inkjet makes for a smoother and thinner
layer than other methods.
ST
2007-02-27 by William Nelson
OK I see the total board is coated with a very thin layer, then they process as usual. Seems like
that would have to be one humongus inkjet to do boards fast.
On Tue, 27 Feb 2007 20:30:41 +0100, William Nelson
<wnnelson@...> wrote:
> Seems like
They coat wafers, not boards. But wide inkjets are not uncommon, even a
cheap C84 has a head maybe an inch wide.
ST
