Homebrew PCBs
Black to Magenta?
Black to Magenta?
2007-03-29 by kpyro2
What are you guys that are doing direct print using to
convert your black and white images to magenta and white?
I cant seem to find a easy method.
Thanks
Ken
Re: Black to Magenta?
2007-03-30 by hwllkym
> Thanks
> Ken
> Ken
> After saving the image from eagle , I use IrfanView, negative then
> Edit palette ,double click the black box, select new color then save.
> a couple of mouse clicks is all it takes.
> Kym
2007-03-30 by pgdion1
> Thanks
> Ken
One way I know of off hand is to print the gerber to a file and then
use a free program called GC-Prevue (gerber viewer is free). You can
open the gerbers and set the colors for each layer (change them to
whatever you want). Then print from there.
Phil
KA0HBG
Re: [Homebrew_PCBs] Re: Black to Magenta?
2007-03-30 by Jacques MEUNIER (P)
Hello
you have not to "print" gerber file but "export" gerber file ;-)
work perfectly here with DipTrace and GC-Prevue
Jacques
  Sent: Friday, March 30, 2007 3:37 PM
  Subject: [Homebrew_PCBs] Re: Black to Magenta?
  > Thanks
  > Ken
  Phil
  KA0HBG
  Email analysé par PC Tools Spyware Doctor (5.0.0.176)
  Version de la base de données : 5.06990
  http://www.pctools.com/fr/spyware-doctor/
2007-03-31 by kpyro2
> > Edit palette
> > Kym
WOW has IfranView changed since the version I had.
This worked Perfect and EASY!
Thanks
 Ken
This worked well also Its a little more confusing but MAY be a cleaner
conversion from protel. I have been printing to a PDF file then
converting in photoshop and now IrfanView but the end result looks good.
Thanks
Ken
2007-03-31 by epineh
> Thanks
> Ken
If I am printing from Eagle, I just make all traces, pads etc that I
want to "keep" the default red colour that Eagle uses for the top
layer, standard Durabrite ink, works well, for the REALLY small
traces as well - and print directly from Eagle to copper.
For the downloaded black PDF's I am using Photoshop to replace the
black with megenta, though I haven't perfected the levels yet, will
as soon as I work it out.
Russell.
2007-04-01 by hwllkym
> > > Edit palette
> > > Kym
> Thanks
>  Ken
> Ken
> I also find the printout From Irfanview is better
> as i can adjust where it prints to on the Carrier
> and the Preview is very helpfull.
> Kym
