Lacqure Pen test
2007-05-06 by Brian Gracia
Has anyone tried this? Take a fine tipped black Sharpie, drill a small hole in the end and insert and seal a small flexible pipe. Connect this pipe to a syringe filled with laqure. Using the Z axis on a home cnc setup, press the plunger down as the Sharpie moves. This should give better coverage. Just my thoughts, Brian G.
