Homebrew PCBs
Heated etchant rocks!
2007-05-18 by DJ Delorie
Today I remembered to heat my etchant.  I just ran hot tap water into
a large container, and floated the FeCl container in it.
Although it had cooled some (the water bath) by the time I got around
to etching (had problems with blue TT paper, ended up using white),
the etchant was still warm enough that the copper almost seemed to
just wipe off with the sponge!  The board was etched in no time.
So if any of you haven't tried heating your etchant yet, try it!
DJ
Re: [Homebrew_PCBs] Heated etchant rocks!
2007-05-18 by Roland F. Harriston
Basic:
All  chemical reactions are speeded up under heating.
Most "Pro" etch machines have heaters.
Roland F. Harriston
> DJ
2007-05-18 by Adam Seychell
I put the FeCl3 etchant directly in the microwave oven. Much more
efficient in both time and energy. Strangely, the liquid does not seem
to be conductive enough to cause excessive localized heating on the
plasticware.
Adam
2007-05-18 by Dale Chatham
Submersible aquarium heaters work quite well.  submersible pumps work
well also.
Aeration creates aerosols that you probably don't work.  I etched the
heads off of every nail in a storage shed that way :)
Roland F. Harriston wrote:
> Basic:
> Roland F. Harriston
>> DJ
> http://groups.yahoo.com/group/Homebrew_PCBs
> If Files or Photos are running short of space, post them here:
> http://groups.yahoo.com/group/Homebrew_PCBs_Archives/
Adam Seychell <a_seychell@...> writes:
I'm pretty sure my wife wouldn't like that.
I got used to the hot water bath technique when the kids were babies
and we had to warm up their bottles.  It was much more consistent and
predictable than the microwave, and with today's bath, I just put it
in there before setting up everything else, and when it was time to
etch it was ready to go - no waiting, no checking.
2007-05-18 by Jan Kok
> plasticware.
Weird, I had the exact opposite experience. I put a 16 oz bottle of
fairly fresh FeCl3 in a microwave (with no turntable). Within a couple
seconds of turning on the microwave, the etchant was boiling around
the meniscus, and started to melt the plastic bottle. Fortunately I
stopped the microwave before the bottle had a chance to spring a leak.
- Jan
I too use the full strength FeCl3, but I don't think that will make it
less conductive. My oven has a turntable, so maybe that makes all the
difference. It could also be you have a fair more powerful oven, as mine
is a fairly old 700W. I've never seen a domestic microwave oven without
a turntable. The etchant does get hotter at the meniscus , but I've
never witnessed boiling. I usually do it in 30 second bursts followed by
a quick stir just to make sure I don't run into those troubles.
2007-05-18 by Bryan Pope
> well also.
So aeration is not the same as having bubbles in the etchant?
That sounds like it makes it harder for the walls to stay put.... !
Bryan
2007-05-19 by Roland F. Harriston
I hate make harsh comments on any public forum,
but I think that heating ferric chloride in a microwave
oven is sheer insanity.
The outgassing of fumes will attack and destroy all
metallic circuit components in or near the oven, including circuit boards
copper (and aluminum, and steel) wiring, etc.
I don't  think I've ever, in my 40plus years in the
electronics biz, every heard of anything as bazaar as
"cooking" an etchant in
a microwave oven.
Sorry for the rant,  but I just can't let this one
go by without moaning and groaning.
Roland F. Harriston
2007-05-19 by Stefan Trethan
So what?
If you notice corrosion you can just bring the oven back to the junk place
and take another with you.
(Keep the transformer if you don't have a battery spot welder yet).
Microwave ovens are usually free, because they are dumped when still quite
easy to repair. The fan blows air into the electrical compartment (usually
right) and through the cooking chamber, and out the other side. The dirty
air does not touch the electrics (it is designed that way to keep food
dirt off it). So worst case it'll start to rust somewhere...
FeCl doesn't gas much, i would not heat cucl, ever, microwave or not.
ST
On Sat, 19 May 2007 02:26:27 +0200, Roland F. Harriston
> a microwave oven.
> Roland F. Harriston
2007-05-19 by Adam Seychell
True. The HCl fumes from CuCl etchants are very corrosive. Although
FeCl3 does have a tiny bit of HCl, its fumes are much less.
On Sat, 19 May 2007 08:08:10 +0200, Adam Seychell
HCl has a very low boiling point.
Even under the boiling point fuming is much increased (look at a cup of
tea).
I once tried to heat a tiny amount of CuCl in a small glass to compare to
room temperature, but when i moved my head over the glass i soon dismissed
the idea.
ST
RE: [Homebrew_PCBs] Heated etchant rocks!
2007-05-19 by Tony Smith
> So what?
> the junk place and take another with you.
> when still quite easy to repair. The fan blows air into the
> side. The dirty air does not touch the electrics (it is
> designed that way to keep food dirt off it). So worst case
> ST
Out of dozens of microwaves I've scavenged, all but one would have worked
with minor repairs.  The exception had a shorted transformer.  Sparks!!!
The rest had a blown fuse.  That's it.  Junked for a $0.50 part.
Ok, in some cases the varistor (spike supressor) had died, and these tend to
fail shorted.  That takes out the fuse as well.  The other way to blow the
fuse is to try to defeat the door locks.  If you look at the wiring, they
are often rigged so the if one of the microswitches (sometimes up to 6!)
doesn't close, then it causes a dead short across the AC, or ties the AC to
ground (which takes out the breaker as well).  Might fry the microswitch
too.
The curious thing is that as ST says, the air vents thru the food
compartment & out the back.  This means the fans get a lot of crap on them,
but everyone I've tested has worked, no matter how grotty.  If the fan did
fail then the thermal cutout (one on the food comparment, one on the
magentron) will trigger.
That junked microwave you walked past works, go grab it.  Dunno about
heating FeCl (I used the double bowl method), but you can dry green wood
with it.  I wish those dudes melting metal would get a move on.
Tony
> have a fair more powerful oven, as mine is a fairly old 700W.
> I've never seen a domestic microwave oven without a
The ones without a turntable have what's called a 'stirrer' up the top.
It's just metal fan in front of the magnetron that bounces the waves around.
I've seen exactly one one these.
I'm not sure why domestic oven use rotating turntables (price,
reliability?).  I think commercial ovens still have stirrers as it means the
handles on the containers you put in will be in the same spot when you open
the door.  Some domestic ovens will rotate the turntable to the 'starting
point' to get the same effect.
Tony
On Sat, 19 May 2007 10:31:53 +0200, Tony Smith <ajsmith@...>
> around.
> the
> open
> Tony
I have seen three with stirrers, usually the larger ones have them but i
also have a very small very early oven with one.
IMO the superior method over the turntable, but a bit more tricky
technically.
One i looked into used a plastic ball bearing (just like metal only clear
balls). I suspect the metal ball bearing would cause arcing and wouldn't
work. The stirrer was powered by the cooling airflow (so the friction
needs to be low).
ST
> them but i
> technically.
> metal only clear
> and wouldn't
> friction
> needs to be low).
> ST
The small one I saw had the stirrer run off the airflow.  I suppose that
would clog up the bearing eventually.  Makes sense that they'd work better,
fewer cold spots.
A quick rummage around Google shows stirrers are still around.  Some models
have them in the sides as well.  These are commercial ones, and are driven
by motors (with belts).
Tony
2007-05-20 by DJ Delorie
Had to do more adapter boards, this time I timed the etch.  The FeCl
was up to temp (no delay this time), so it was about 115-120F.  Single
sided 1/2 oz copper, the board was 1x2".
Etch time: 90 seconds!
