Homebrew PCBs
Circuit on glass substrate
2007-07-23 by jeromedecock
Hi!
I have one of these VFD display (http://www.jogis-roehrenbude.de/
Roehren-Geschichtliches/Nixie/ILZ-1.htm ) russian made and it has a
circuit "printed" on glass. The traces are clean and the substrate is
transparent, anybody knows how these are produced? I would like to
have a glass / transparent PCB with solderable tracks.
Thanks!
Re: [Homebrew_PCBs] Circuit on glass substrate
2007-07-23 by Roland F. Harriston
Most likely vacuum deposition, commonly called "sputtering"
Roland F. Harriston, PD
jeromedecock wrote:
> Hi!
> <http://www.jogis-roehrenbude.de/>
> Thanks!
Re: Circuit on glass substrate
2007-07-25 by jeromedecock
Thank you. Any link to a producer (using sputtering) for like 300
pieces maximum?
Otherwise I found this screenprintable ink Electrodag 461SS (from
Acheson Colloids) that has to be cured in between 70 and 250 Degrees
(C). Anyone has experience with screen printing circuits (with heat
cured inks) ?
--- In Homebrew_PCBs@yahoogroups.com, "Roland F.
Re: [Homebrew_PCBs] Re: Circuit on glass substrate
2007-07-25 by Roland F. Harriston
GTG.............
i.e. Go To Google.
I think that some of the people who do art work on stained glass, might
lead you into
outfits that do sputtering.  The technique is very common in the
semiconductor fab industry.
I just did a 10 second Google and came up with the
URL below where the person explains how he made his own sputtering rig
out of a pressure cooker, power supply, and few other items.
> http://yarchive.net/metal/vacuum_deposition.html
> pieces maximum?
> cured inks) ?
> --- In Homebrew_PCBs@ yahoogroups. com
> <mailto:Homebrew_PCBs%40yahoogroups.com>, "Roland F.
2007-07-25 by dandumit
It seems that this ink cold be very well used for trough hole plating.
At least I have seen something similar at LKPF...
Have you seen any conductive ink that could printed with an inkjet
printer ?
> pieces maximum?
> cured inks) ?
