Homebrew PCBs
Riston Plate Master Dry Film
2007-08-16 by Mr Crazy
Hi All,
I am new around here and new to the filed of etching. Though I have tried things with toner transfer and it has worked but I couldn't get rid of pin holes that appear because toner not getting fully transfered. I have tried Toner Transfer thro' Acetate/ Laser Transperancies.
Now, I want to try this with Dupont Riston Plate Master Dry Film. Has anybody used this dry film for making PCB at home?
Are all dry films require same processing? Any experiences, suggestions.
I have gone thro' Dupont datasheet for the film, but since I am not very techie, I didn't understood some stuff, so if anybody has tried, experience will be of great help. (http://www2.dupont.com/Imaging_Materials/en_US/assets/downloads/datasheets/pm200.pdf)
I have found good article about "How to laminate dry film photoresist". (http://www.megauk.com/datasheets/5180_Data_Sheet_Dry_Film_Photoresist_(How_to_Laminate).pdf)
But not sure if it will be same for Dupont Riston. What about exposure, that will also be same as any other dry film. How much power UV light source is required?
Thanks Steve for allowing me to join the group.
Parag
Choose the right car based on your needs.  Check out Yahoo! Autos new Car Finder tool.
Re: [Homebrew_PCBs] Riston Plate Master Dry Film
2007-08-16 by Leon
To: <homebrew_pcbs@yahoogroups.com>
Sent: Thursday, August 16, 2007 7:15 PM
Subject: [Homebrew_PCBs] Riston Plate Master Dry Film
> Hi All,
> source is required?
Have you tried using pre-coated positive resist boards? If not, get your
process working properly with those first.
Leon
Leon Heller
Amateur radio call-sign  G1HSM
Yaesu FT-817ND transceiver
Suzuki SV1000S motorcycle
leon355@...
http://www.geocities.com/leon_heller
