Aoyue 968
2007-08-24 by brainerd@wildblue.net
I just got the Aoyue 968 about 2 weeks ago. I don't have any experience with other units to compare to. I am currently assembling my 995x board which has several several QFN package IC's, some ssop packages with .65 mm pin spacing, and an AD9954 with .5mm spacing. I used the temperature controlled soldering iron for most of it. I bought the smallest tip they offered. It is small enough I can solder individual pins on the 9954 under a microscope. It is the first temp. controlled iron I've used and is very nice. I also ordered the vacuum pick-up attachment. I tried it, but found that it would not release the part when I uncovered the hole on the side. I had to knock the part off of the tool or turn off the vacuum. This makes it pretty much useless for placing parts on the board. I used the hot air and solder paste on a smd oscillator and a QFN device. With the air set at 250 deg. C and the air flow just above minimum, it had no trouble melting the soldering paste. Dave - WB6DHW <http://wb6dhw.com> [Non-text portions of this message have been removed]
