New to this group! - Toner Transfer questions
2007-09-10 by WB2LCW
<subject line edited by mod> Hi Guys! My name is Mike and I just started experimenting with toner transfer. Here I would like to list my findings so far. I used Staples picture paper in my trials! I made a circuit copy to Staples paper and one pass thru the printer. The traces adhered about 85 percent.This is my first try.The paper was not that easy to remove. I then tried with one pass thru the printer for the traces then I brought up Notepad, typed one period then ran the paper with the traces thru again .I ironed on the traces. The paper had a bubly look but peeled off much easier..The adhesion was excellent and better than 95 percent went on perfectly!remainder came off easily with a old toothbrush! I find traces within .2 inces of the edges of the board were not the best. On my next ry I will pay more attention to the edges with my iron! This may be because the edges cool off faster than the rest of the board! But all the rest were absolutely perfect and they were narrow traces .007 to .010 inch! Now for my iron! On my first try I used my wife's steam iron.But the soles of steam irons have holes and dimples. I was in a variety store and I found a Chinese made DRY IRON! This iron has a sole plate that is flat with no holes ,so the full plate rests on the board and transfers heat better. This iron I used on my second attempt. It only cost me $10 dollars.. Some where on the web I came accross a item where the person posting said he used a one inch wooden dowel under his board so that pressure from the iron is concentrated at that point. I used a oven mitt to handle the board while ironing.The board handles like a polly Polly that is why the mitt is neccessary! Regards Mike
