Homebrew PCBs
TouchUp Pens??
TouchUp Pens??
2007-10-15 by Bob Macklin
I finally got a good toner transfer on the 1/32" board. Now I need to
fill the pin holes.
I do have some Sharpies here. But I also ave some artists acrylic pens.
Has anyone ever tried the acrylic pens?
Bob Macklin
Seattle, Wa.
Re: [Homebrew_PCBs] TouchUp Pens??
2007-10-15 by sml
what method did you use to get a good transfer?
> fill the pin holes.
> Bob Macklin
> Seattle, Wa.
First I tried this on 1/16" stock. When that worked I
went to the 1/32" piece.
What I had been doing is just holding the iron in one
place under a much pressure as I could generate for 5
minutes. My board is small enough to fit the area of
the iron that has no holed. But I got very
inconsistant results that way.
I held the TT paper in place with one finger while I
tacked it to the copper. Once it was tacked to the
copper I "IRONED" it with the tip of the iron for 5
minutes.Buy the time I had dome this for 5 minutes the
top of the paper was almost totally black. Then I put
it in the water for the 10 minute soaking period.
At least this is a starter.
Now I need to clean it up before etching. This is a
double sided board. I don't expect this one to be
useable. Right now this is a learning process.
I am a retired EE. I was close to the PCB industry for
many years. I laid out PCBs for a living at times. I
am using Orcad for the artwork.
Bob Macklin
Seattle, Wa.
Re:TouchUp Pens??
2007-10-16 by RICHARD HEILIGER
I don't get pinholes!!
Look at my post under TT Technique.
Use the right paper.
RD
