Homebrew PCBs
To tin or not to tin
2007-11-24 by Dave
Is tinning necessary? What is the most cost effective way to buy the
tinning solution and how is it applied? I usually buy bulk if things
don't have shelf life to worry about.
Dave
Re: [Homebrew_PCBs] To tin or not to tin
2007-11-24 by Dylan Smith
I tin my boards because they look nicer, in the main! (The copper
tarnishes rather fast).
The tinning crystals last a longn time, but made up solution breaks down
after a few months - so make it up in small amounts.
2007-11-24 by Dave
Where is the best place to buy the tinning crystals?
Dave
2007-11-24 by Leon
To: <Homebrew_PCBs@yahoogroups.com>
Sent: Saturday, November 24, 2007 4:05 PM
Subject: [Homebrew_PCBs] To tin or not to tin
I find the small amount of resist left on the board after cleaning it off
with IPA stops the tracks from corroding.
Leon
Leon Heller
Amateur radio call-sign G1HSM
Yaesu FT-817ND and FT-857D transceivers
Suzuki SV1000S motorcycle
leon355@...
http://www.geocities.com/leon_heller
Really depends where in the world you are - I got mine from RS Components
by mail order. (http://www.rswww.com)
2007-11-24 by Craig vk2zcm
Hi Guys
 I tried your link but got
No results were found for tinning crystals
maybe they are knowen as some other name?
  Sent: Sunday, November 25, 2007 7:31 AM
  Subject: Re: [Homebrew_PCBs] To tin or not to tin
2007-11-25 by Dylan Smith
On Sun, 25 Nov 2007, Craig vk2zcm wrote:
> Hi Guys
Try RS catalogue number 567-812
They are a bit expensive though, but 450g should last years if you only
make up a small amount of solution at a time (made up solution doesn't
keep for all that long, best I've got is about 4 months - but the crystals
themselves last for a long time. I keep made-up solution in one of those
expanding photo developer bottles so I can exclude as much air as
possible).
RE: [Homebrew_PCBs] To tin or not to tin
2007-11-25 by Mark Mickelsen
Does anyone know where to get these tinning crystals in the USA?
Mark
  _____
From: Homebrew_PCBs@yahoogroups.com [mailto:Homebrew_PCBs@yahoogroups.com]
On Behalf Of Dylan Smith
Sent: Saturday, November 24, 2007 5:49 PM
> Hi Guys
possible).
Re: To tin or not to tin
2007-11-25 by Ben
> Thanks,
> Dave
I do not tin my boards.  I use the positive method using the MG
Chemcials 600 series boards.  I leave the resist on, you do not have
to remove to solder.  I also once I have loaded the board spray the
bottom with clear laquer.  The clear laquer would also work well if
you do TT method as it will seal the copper.
2007-11-25 by Ben
Components
Also try Allied Electronics www.alliedelec.com or Mouser www.mouser.com
they both carry some of the MG Chemical products.  I don't do the
Tinning myself anymore so it has been a long time since I have bought
any.
Ben
2007-11-25 by Ben
> Components
www.mouser.com
bought
> any.
> Ben
Another one you can try is Circuit Specialists, Inc.
www.web-tronics.com
Ben
2007-11-25 by Dave
Mark
Mark,
I found these 2 places. The second place is slightly cheaper but they
are out of stock until the 27th of Nov which is just a few days away.
Dave
http://www.allelectronics.com
http://www.partsexpress.com/pe/showdetl.cfm?Partnumber=340-188
> ,_._,___
2007-11-25 by Dave
 > Leon
I don't know if it matters but I plan on using the Gootee method so I
just ordered some tinning crystals to be safe. If I don't feel the need
to use them I can do without later. I am just getting my materials in
order before I start.
Dave
2007-11-26 by Stefan Trethan
The tinning solutions all seem to contain pretty nasty chemicals, so
take appropriate care.
There is also hot tinning, or coating with various other stuff as alternative.
ST
