Homebrew PCBs
Silkscreen question
Silkscreen question
2007-12-03 by Dave
How are you guys doing the silkscreen layer to the component side of the
board? I only have a black laser printer. Don't tell me I need to buy a
color one too? :) Is that the usual way and does black work ok when
using the TT method for this?
Dave
Re: [Homebrew_PCBs] Silkscreen question
2007-12-03 by Leon
To: <Homebrew_PCBs@yahoogroups.com>
Sent: Monday, December 03, 2007 4:07 PM
Subject: [Homebrew_PCBs] Silkscreen question
I don't bother with one.
Leon
2007-12-03 by DJ Delorie
I don't bother either, but Pulsar has a white film that irons on over
black toner to give you a white silkscreen.  I suppose you could use
the blue press-n-peel the same way.
When I do do a silkscreen, I usually just go with black.
http://www.delorie.com/pcb/liquidtin/board-silk.html
2007-12-03 by Harvey White
Two methods, one TT, on not.
TT: create the SS layer, then transfer it to the top of the board. Use
white film (from Pulsar) and laminate again.  Use tape to remove the
excess.  Instant silk screen layer.  Be careful of SMT devices,
though.
Not:
Take a transparency and reverse print it (reverse the image) so that
you have to view through the transparency to see the image.
Reverse and glue to top of board (or use carpet tape).  Drill board.
Color can be used.
Note that there is no "white" ink jet ink available, and I have never
heard of "white" toner...
Harvey
>Thanks,
>Dave
2007-12-03 by Dave
> though.
> Not:
> Color can be used.
> Harvey
>> Thanks,
>> Dave
Sounds good to me. I am using single sided boards so using the TT method
will it transfer to the fiberglass or non-copper layer ok?  Or is that
what plan B is for. :)
Dave
2007-12-03 by Dave
Thanks for the info and links. I need to check into the Pulsar stuff. I
have lots to learn yet. :)
Dave
2007-12-03 by Mark Brueggemann
I prefer Press'n'Peel to the Pulsar product but the Pulsar TT
paper is good for silkscreens.  I don't normally do it but
sometimes customers request it.  The black toner shows up
reasonably well on copper and lighter substrates.  I clear
coat it with spray clear enamel, otherwise it's somewhat
fragile to handle.  And, you have to be very careful not to
get flux remover on it, or it's gone/blurred in a flash.  It
can look very professional though, since you can put text
and graphics on the board.  I try to do as much of that in
copper as I can (in copper pour or blank space) so that a
silkscreen becomes less necessary for assembly/operation.
Mark K5LXP
Albuquerque, NM
Dave <theschemer@...> writes:
It should.  In my photos it didn't, but that wasn't fiberglass - it
was an old THICK phonelic board, and the laminator just didn't get hot
enough to adhere it properly (it started to adhere in some places).
There might not have been enough pressure getting through to those
narrow places, as that may have been a 2oz board also.
On Mon, 03 Dec 2007 13:19:41 -0600, you wrote:
Works on both copper and fiberglass, so no problem with the TT stuff.
The transparency method was used mostly with single sided boards that
were photoexposed and etched.
Details at www.dragonworks.info  If the top links do not work, then
please navigate through the menus and that ought to do the trick.  The
individual index pages are OK.
Harvey
>> though.
>> Not:
>> Color can be used.
>> Harvey
>>> Thanks,
>>> Dave
>Thanks,
>Dave
2007-12-03 by Dave
> Harvey
I see. So the transparency cut out and taped is just for more protection
to the SS. I guess why I am asking is that I never used transparencies
before. Once you use them they are toast correct. One use only? So after
you iron on a transparency it is not to be cleaned up and reused? Just
asking so I know as I just ordered me an HP 1022 LaserJet.
Dave
On Mon, 03 Dec 2007 14:32:12 -0600, you wrote:
OK, the transparency is a single use item.  You don't iron it on,
because that puts a layer of something (goo) on the board.  Of course,
there's the glue you use to hold it on, but in that case, you have a
choice of what to use.  You reverse it so that the printing is on the
bottom, and won't be easy to wear away.  Goes on the top of the board,
of course.
You laser print on the back of the transparency, that's the SS layer.
You could just as easily go color with transparency film and an ink
jet.
Harvey
>> Harvey
>Thanks,
>Dave
Re: Silkscreen question
2007-12-03 by warrenbrayshaw
Nice end result.
Can you tell me what solder and defluxer you are using that leaves the
toner in such good shape.
Many Thanks
Warren
2007-12-03 by Anthony Clay
> and I have never
I'm planning on converting an epson printer into a
dedicated silkscreener.  (Basically, it's a
piezoelectric print head, and a heater for the circuit
board to help the ink distribute.)
Instead of using factory ink, try using heat-curing
ink in the print heads - simply replace RGB
w/whatever, and print "red", "blue", "green" to use
whatever is in the slot. Basically, just get the board
warm/hot, print on it, then heat to "cure" the board.
Looking for last minute shopping deals?
Find them fast with Yahoo! Search.  http://tools.search.yahoo.com/newsearch/category.php?category=shopping
Re: [Homebrew_PCBs] Re: Silkscreen question
2007-12-04 by DJ Delorie
"warrenbrayshaw" <warrenbrayshaw@...> writes:
For that specific board, it was SYNTech solder paste, no-clean.
2007-12-04 by Myc Holmes
I found the simplest way to create black TT legends is to first give the top
side of the pcb a light coating of white Krylon spray paint. Red also looks
pretty good.
Myc
On Dec 3, 2007 6:12 PM, warrenbrayshaw <warrenbrayshaw@...>
> Nice end result.
> Many Thanks
> Warren
2007-12-04 by Stefan Trethan
i use black and it looks great.
You need to transfer it without the white paper fuzz or remove that afterward.
But then, i'm using PCB stock that is very yellow in color. With the
almost transparent FR4 you might have less visibility, but i would
expect it to be OK.
I found that it does not hold well on the smooth side of single-sided
stock. It sticks like crazy to the epoxy where copper was etched away
(rough surface). But i have mostly double sided stock anyway.
ST
> Thanks,
> Dave
> http://groups.yahoo.com/group/Homebrew_PCBs
2007-12-04 by Dave
> pretty good.
> Myc
Good idea. I will try it some time...
Dave
2007-12-04 by Dave
> of course.
> jet.
> Harvey
Ok, thanks for clearing that up. I need to buy some transparencies for
both ink jet and laser then so I can see which works for me.
Dave
2007-12-04 by Dave
>> and I have never
Let us know how that conversion goes :) Sounds like an interesting
project but not one I am ready to tackle right yet. :)
Dave
2007-12-04 by Dave
Stefan Trethan wrote:
> Hi,
> expect it to be OK.
> ST
I have some old single sided boards I purchased years ago. They have the
word "Milacron" on the non-copper side. They are an off-white so black
will look good there. I am still getting organized but trying to get off
to a good start.
Dave
2007-12-04 by Harvey White
>> of course.
>> jet.
>> Harvey
You buy the type of transparency for whatever machine you have, of
course.  IIRC, if you run an inkjet transparency through a laser
printer you face the possibility that the plastic will melt.
Harvey
>Dave
2007-12-04 by Dave
> Harvey
I think they used to warn us of using Ink Jet Glossy Photo paper in a
laser printer too as it could ruin it. Has that been proven false or do
I need to use laser glossy printer paper in my laser printer?
Dave
