Homebrew PCBs
GBC H210 laminator for $40 after rebate at Staples this weekend
2008-02-17 by davemac2
For those looking for a laminator for some PCB work, Staples has what
appears to be the H210 laminator on sale this President's Day weekend
for $40 after an instant discount and rebate.  Lsit price on that one
is omsehting like $150, so it's a good deal.  I can't find anything
mentioned about it on their website or electronic ads, but in my local
flyer, it is listed in a very small square on the bottom of one of the
inside pages.  So it is probably store only and not online.  This
laminator has an adjustable feedrate and can accomodate 9.5" wide
material.
dave mc
Re: [Homebrew_PCBs] GBC H210 laminator for $40 after rebate at Staples this weekend
2008-02-17 by agscal -AGSCalabrese
Good tip , Dave
Maybe it can be modified to optionally expose photo-resist as a board
passes through.  Heat turned off.
Gus
> material.
> dave mc
RE: [Homebrew_PCBs] GBC H210 laminator for $40 after rebate at Staples this weekend
2008-02-18 by Mark Mickelsen
Hi Dave,
Okay, I found the add in the paper and tomorrow I'm going to Staples to see
if they've got any left.  In the meantime, has anybody tried this laminator
to see how it works with the process of toner transfer?  It'd be nice to
hear that someone has successfully completed the transfer of a pattern using
this machine.
Anyway, gonna' try to find out what I can on my own.  If I find anything
out, I'll try to report it back.
Warm regards,
Mark
  _____
From: Homebrew_PCBs@yahoogroups.com [mailto:Homebrew_PCBs@yahoogroups.com]
On Behalf Of davemac2
Sent: Sunday, February 17, 2008 12:50 PM
Subject: [Homebrew_PCBs] GBC H210 laminator for $40 after rebate at Staples
this weekend
material.
dave mc
2008-02-22 by Travis Tabbal
Any luck? I found some locally and if it works well I thought it would be a
good buy for my first attempt at toner transfer.
On 2/18/08, Mark Mickelsen <mark.mickelsen@...> wrote:
>   Hi Dave,
> see
> using
> this machine.
Re: GBC H210 laminator for $40 after rebate at Staples this weekend
2008-02-25 by niponcio
Ive been using this laminator, I think it works great, I have managed
to get traces down to 0.008"  (they tend to get a little thicker with
the paper Im using) with a clearance of .01". I set it on temp 5 and
pass the board 3 times.
Then I lower the temp to 2 and apply the green foil (2 passes).
The only problem is that if you plan to use 1/16" thick copper clads,
you have to help them pass through. 1/32" cooper clads work great,
which, for what Ive seen is not a problem if you live in the states
because they are just about the same price, or at least thats what
digikey says. (I have to work mostly with 1/16 because, where I live
they are really cheap and they are the only ones available)
Hope this helps
regards
would be a
> >   Hi Dave,
Staples to
> > see
laminator
nice to
> > using
> > this machine.
anything
Re: [Homebrew_PCBs] Re: GBC H210 laminator for $40 after rebate at Staples this weekend
2008-02-25 by Travis Tabbal
Thank you! I have ordered some 1/32" boards for testing it out with. I'm
glad to hear it works well for someone. I purchased the laminator and left
it in the box just in case someone said it doesn't work so I can return it.
:) Now I have to remember to send in the rebate.
