Solder paste advice
2008-04-23 by Dylan Smith
Hi list, For the first time today I used solder paste. Much nicer way of soldering fine pitch SMD - using the soldering iron to do it was getting old rather fast. My method was to lay down a bead of paste on each row of pads, place the chip, then use a hot air gun. It was nice not to have to spend 15 minutes carefully lining up a big LQFP then bodging it when trying to tack the first pin and starting again. I had read that the component will try and centre itself thanks to surface tension, and this turned out to be a good tip. My main problem at the moment is putting down to much paste rather than too little... but I had far less solder to wick up after soldering than doing it by hand and the result is much neater. The paste I got is Edsyn CR44 - it seemed reasonably easy to apply. I bought a syringe of the stuff. What's the best way of making the solder paste keep for as long as possible? I had heard that it had to be kept refrigerated, and that it would only be sent same day frieght and all this sort of thing but as far as I could tell, Farnell didn't treat the order any differently than any other component (it certainly didn't go with any priority - took 2 days to get to me!)
